new OpenELEC
Discussion in 'XBMC' started by vpeter, Dec 12, 2014.
  1. vpeter
    vpeter Active Member
    Nov 29, 2014
    303
    62
    OpenELEC 5.0.8
    OpenELEC 5.95.1
    http://www.udoo.org/forum/threads/openelec-5-95-2.2421/
    https://drive.google.com/folderview?id=0B4FdVu0-fJt6N3l3QmtpZVJRM1E&usp=sharing#list
    Not tested thoroughly. That's why I'm looking for users who would help supporting images for Udoo.
    Without some better approach there will be no official images for this system. Or at least no bug reports.
    Hi all,
    it takes some time to prepare new OpenELEC build for udoo board based on current state of OpenELEC. As you may be aware there is just one project called imx6 which will cover all devices based on this SoC. Because the project is base for Cubox-i device there are some sw components used which can't be changed. Most important one is Linux kernel 3.14+. So I merge all the work done previously by few users with my little knowledge and now I have udoo supported too (beside Cubox-i and TBS Matrix). Probably not everything is perfect yet but it is close enough.
    OpenELEC 5.0.4: OpenELEC-imx6.arm-5.0.4-udoo_quad.img.gz
    (still no analog output)
    OpenELEC-imx6.arm-5.0.0-udoo_quad.img.gz
    OpenELEC-imx6.arm-devel-20141212185955-r19776-g15f1597-udoo_quad.img.gz
    Please test it and let me know how it works. Analog audio doesn't work yet (waiting for driver). Some things must be fixed in Kodi (as for other devices also) and some are related to this device only. One thing I would like to know if CEC is working (don't have TV to test).
    I would like to thank you udoo team to send me the board. And also to notxarb for his work. It was very valuable.
    Viper780 and pingwiniasty like this.
  2. mmeinert
    mmeinert Member
    Jun 17, 2014
    61
  3. vpeter
    Nov 29, 2014
    303
    62
    Yes, you are right. There is no CEC for udoo. At least not without some hardware modification.
    questions-ask-first-t506.html#p4053
  4. delba
    1,064
    Many thanks to you vpeter,
    i'm about to test it. I'll give you some feedbacks asap ;)
  5. JoostK
    JoostK New Member
    Dec 15, 2014
    Seems to be running quite fine on my UDOO Quad. HDMI-CEC adapter from Pulse-Eight was recognised immediately.
    I have been running Stephan's v0.0.6 image in the last couple of months, without much issues. I could never get AirPlay to work and now it seems to be working fine. Also a crash I had when playing certain online streams seems to have been resolved, it plays flawlessly now.
    When browsing the menus I sometimes have up to a second delay in response. I have no idea what causes this, but never experienced something similar with Stephan's build.
  6. vpeter
    Nov 29, 2014
    303
    62
    Maybe because CEC is also enabled on udoo itself. And this doesn't work. Next image will have it disabled.
  7. JoostK
    JoostK New Member
    Dec 15, 2014
    Could be indeed. I must say that Stephan's build also had the chipset CEC enabled, but I didn't have any issues there. Disabling it completely shouldn't be much of a problem, as I don't think one could actually fix the CEC wiring on UDOO.
    I'm going to try this build for a while and see how things go. When I learn more about the delays I will let you know. If there's any information you need otherwise, all you need to do is let me know ;)
  8. vpeter
    Nov 29, 2014
    303
    62
    JoostK, what exactly does it happen with delay? You press a button and action on TV is delayed? Can you check with top command if anything is using much cpu? Also debug log from kodi would be useful to check.
  9. volc
    volc New Member
    Nov 27, 2014
    Sounds good. Downloading!
  10. mmeinert
    mmeinert Member
    Jun 17, 2014
    61
    Ok, time for my feedback, it will be fast : this release works pretty well !
    I don't think it's an issue but I can't disable ssh server, is it because it's not final or am I wrong ?
    vpeter : good work !
  11. vpeter
    Nov 29, 2014
    303
    62
    Open file uEnv.txt on sd card and remove parameters
    ssh progress debugging console=ttymxc1,115200
  12. Qter
    Qter New Member
    Many thanks to vpeter. Great job!!!
    I have one problem with greek charset.
    In settings do not has option to greek layout keyboard.
    Can i do something to solve this problem myself.
    Thanks in advance!
  13. vpeter
    Nov 29, 2014
    303
    62
  14. Qter
    Qter New Member
    great news! I did not know this.
    vpeter thank you for help. I will try it after work.
  15. mmeinert
    mmeinert Member
    Jun 17, 2014
    61
    Perfect, thank you !
    Have seen some movies in various formats, from usb and file server -> WORKS PERFECTLY so far. I'll test some plugins and themes this week-end.
    Greetz
  16. JoostK
    JoostK New Member
    Dec 15, 2014
    I have used my UDOO with Kodi for the past two days (the days before I didn't have the time) and haven't noticed the delays any more, so can't tell or investigate what happened a week ago.
    Video playback seems fine, I have not yet had any crashes or other issues.
  17. vpeter
    Nov 29, 2014
    303
    62
    Good to hear that spend time was not wasted.
    Happy Christmas udoo community.
  18. mmeinert
    mmeinert Member
    Jun 17, 2014
    61
    @vpeter does your work will be upstreamed to official build ?
    I don't have much to say about your release, it works pretty well :)
  19. vpeter
    Nov 29, 2014
    303
    62
    Yes, after 5.0 (soon).
  20. vpeter
    Nov 29, 2014
    303
    62
