Recognizing a SATA drive on my quad
Basic & Installation
Moderators: DracoLlasa, mkopack, ekirei, delba
Postby DangerousThing » Sun Feb 09, 2014 12:35 pm
I want to be able to format and use a 1 TB SSD SATA notebook drive I have.
I have a Udoo quad running under the Ubuntu image on this website. I'm using a 12 volt 5 amp power supply.
I was fairly familiar with Linux 10 years ago, but I seem to have forgotten some of my basics.
I've plugged the drive into the SATA data port, and using the power cable I received with the Starter Kit I plugged that into the port next to the SATA data port, which should be 5 volts, I believe.
I power up the Udoo and go in through the serial port. My only problem is that I can't seem to see the drive, and I don't even know which device in /dev the SATA disk is supposed to be. And then i seem to have forgotten how to format it.
Can anybody help me with this?
Further information: the SSD drive gets warm after a while, so I assume it is getting power.
DangerousThing
Re: Recognizing a SATA drive on my quad
Postby DangerousThing » Tue Feb 11, 2014 12:21 pm
I think I'm on the right track. I put my SSD into a USB case so i could write the same image as is on my SD Card.
Then I put the disk on the Udoo where I was able to find it as /dev/sda.
I then used parted to fix the partition size as well as putting a 3 GB swap partition on the SSD. The information is on the web if you know what questions to ask. I asked: "how to extend an ext3 partition using parted on linux." It turns out you also need a few other programs to fix the filesystems. Right now I'm extending the filesystem to fit the partition (3 hours and going strong).
More later when I find if this actually works.
Jay
DangerousThing
Postby sirrab » Thu Jul 31, 2014 12:12 am
Did extending the partition size work? Commands needed? Thanks!
sirrab
Postby peter247 » Thu Jul 31, 2014 10:11 am
I have a 80 gb SSD and that boots like a dream with only uboot on the sd card , But I`ve found that my 512 gb drive will not boot with only the uboot on the sd card .
My work around is to put uboot and the kernel on the sd card and use the RFS on the sata.
I`m not sure if it`s the size of the drive etc , but some drives will run the kernel off the sata drive , but stop when it comes to mounting the RFS.
peter247
Return to UDOO 101
Who is online
Users browsing this forum: No registered users and 0 guests
