GNOME GREY SCREEN
Discussion in 'Troubleshooting' started by lutin7812, Oct 31, 2015.
  1. lutin7812
    lutin7812 New Member
    Oct 31, 2015
    Hello, try to access UDOO NEO Gnome Interface from VNC but get a grey screen.
    I've followed the VNC tutorial, eg launch vncserver :1 -geometry 800x600 -depth 24.
    Then when I conect with VNC Viewer I get a grey screen with black cross.
    In the ~/.xsession-errors file I have the following log:
    Script for ibus started at run_im.
    Script for auto started at run_im.
    Script for default started at run_im.
    Xsession: X session started for udooer at Sun Nov 1 06:45:58 JST 2015
    X Error of failed request: BadValue (integer parameter out of range for operation)
    Major opcode of failed request: 109 (X_ChangeHosts)
    Value in failed request: 0x5
    Serial number of failed request: 6
    Current serial number in output stream: 8
    localuser:udooer being added to access control list
    Unable to create /home/udooer/.dbus/session-bus
    gnome-session-is-accelerated: No composite extension.
    gnome-session-check-accelerated: Helper exited with code 256
    x-session-manager[1803]: WARNING: software acceleration check failed: Child process exited with code 1
    x-session-manager[1803]: CRITICAL: We failed, but the fail whale is dead. Sorry....
    Any Idea?
    Thank's for help
    Olivier
  2. nophead
    nophead UDOOer
    Aug 18, 2015
    87
    14
    I get the same: grey screen with cursor using TightVNC as the viewer.
  3. Dutch999
    Dutch999 New Member
    Jan 16, 2014
    I'm having the same grey screen issue with VNC. Assuming this is an issue with the xstartup file but haven't been able to find a solution.
  4. nophead
    nophead UDOOer
    Aug 18, 2015
    87
    14
    Ignore the tutorial. Don't start vncserver, there is already a server called Xvnc. Connect to it without a port number and it works. The screen is grey for a few seconds and then you get the blue desktop, the same as the one on the HDMI output.
  5. Andrea Rovai
    nophead, good point! Follow the Neo-Docs, where everything's explained! I guess you followed this tutorial, but it's about UDOO Dual / Quad, not about UDOO Neo.
  6. nophead
    nophead UDOOer
    Aug 18, 2015
    87
    14
    Well yes of course I would have followed the Neo docs version had it existed at the time.
    It seems odd they would be different though. Seems like most of the Ubuntu side could be exactly the same to avoid having duplicate docs and having to know about two systems. Are you going to bring them back together at some point?
  7. Andrea Rovai
    Sooner or later we'll do it, but I'm afraid many people would be confused, aren't you?
  8. nophead
    nophead UDOOer
    Aug 18, 2015
    87
    14
    The confusing thing is why the Neo is different from the quad and a raspberry pi when it comes to VNC. I was already familiar with VNC on RPi, so when I found the Udoo Quad instructions with Google, that where essentially the same, I expected them to work on the Neo as well. They work on pretty much any other Ubunto machine. I guess it is because you have installed xvnc instead of vncserver and somehow that blocks vncserver for accessing X.
