How to install TP-Link TL-WN722N USB Wireless Adapter
Discussion in 'Debian' started by rlagonda, Oct 3, 2014.
  1. rlagonda
    rlagonda New Member
    Oct 3, 2014
    I have some problems on installing TP Link USB Dongle on my udoo. I also asked similar question here:
    http://superuser.com/questions/8200...n-usb-wireless-adapter-on-debian-wheezy-armhf
    more information:
    root@udoo-debian-hfp:~# lsusb
    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    Bus 002 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
    Bus 002 Device 096: ID 0cf3:9271 Atheros Communications, Inc. AR9271 802.11n
    Bus 002 Device 004: ID 148f:5370 Ralink Technology, Corp. RT5370 Wireless Adapter
    root@udoo-debian-hfp:~# dmesg
    [    0.949320] imx-ipuv3 imx-ipuv3.0: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
    [    0.969314] imx-ipuv3 imx-ipuv3.1: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
    [    0.977147] mxc_mipi_csi2 mxc_mipi_csi2: i.MX MIPI CSI2 driver probed
    [    0.983625] mxc_mipi_csi2 mxc_mipi_csi2: i.MX MIPI CSI2 dphy version is 0x3130302a
    [    0.991357] MIPI CSI2 driver module loaded
    [    0.995703] Advanced Linux Sound Architecture Driver Version 1.0.24.
    [    1.002932] Bluetooth: Core ver 2.16
    [    1.006639] NET: Registered protocol family 31
    [    1.011110] Bluetooth: HCI device and connection manager initialized
    [    1.017485] Bluetooth: HCI socket layer initialized
    [    1.022385] Bluetooth: L2CAP socket layer initialized
    [    1.027540] Bluetooth: SCO socket layer initialized
    [    1.032886] cfg80211: Calling CRDA to update world regulatory domain
    [    1.040357] i2c-core: driver [max17135] using legacy suspend method
    [    1.046645] i2c-core: driver [max17135] using legacy resume method
    [    1.052874] Switching to clocksource mxc_timer1
    [    1.072878] NET: Registered protocol family 2
    [    1.077426] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
    [    1.085354] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
    [    1.094697] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
    [    1.102437] TCP: Hash tables configured (established 131072 bind 65536)
    [    1.109087] TCP reno registered
    [    1.112247] UDP hash table entries: 512 (order: 2, 16384 bytes)
    [    1.118232] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
    [    1.124950] NET: Registered protocol family 1
    [    1.129650] RPC: Registered named UNIX socket transport module.
    [    1.135591] RPC: Registered udp transport module.
    [    1.140332] RPC: Registered tcp transport module.
    [    1.145052] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    1.151530] PCI: CLS 0 bytes, default 32
    [    1.152417] PMU: registered new PMU device of type 0
    [    1.157543] Static Power Management for Freescale i.MX6
    [    1.162788] wait mode is enabled for i.MX6
    [    1.167081] cpaddr = c0880000 suspend_iram_base=c08fc000
    [    1.172518] PM driver module loaded
    [    1.176412] IMX usb wakeup probe
    [    1.179777] the wakeup pdata is 0xbfed3000
    [    1.180163] add wake up source irq 75
    [    1.187476] IMX usb wakeup probe
    [    1.190791] the wakeup pdata is 0xbfda9580
    [    1.191002] cpu regulator mode:ldo_enable
    [    1.195223] i.MXC CPU frequency driver
    [    1.225574] JFFS2 version 2.2. (NAND) \xffffffc2\xffffffa9\xffffffa9 2001-2006 Red Hat, Inc.
    [    1.232468] fuse init (API version 7.16)
    [    1.237304] msgmni has been set to 1749
    [    1.242748] alg: No test for stdrng (krng)
    [    1.247012] io scheduler noop registered
    [    1.250969] io scheduler deadline registered
    [    1.255345] io scheduler cfq registered (default)
    [    1.261179] MIPI DSI driver module loaded
    [    1.265380] mxc_sdc_fb mxc_sdc_fb.0: register mxc display driver hdmi
    [    1.271893] mxc_hdmi mxc_hdmi: Detected HDMI controller 0x13:0xa:0xa0:0xc1
    [    1.278817] fbcvt: 1920x1080@60: CVT Name - 2.073M9
    [    1.283719] fb_videomode = 59 1920 1080 5780 328 128 3 32 200 5 2 0 32
    [    1.302377] imx-ipuv3 imx-ipuv3.0: WARNING: adapt panel end blank lines
    [    1.317520] imx-ipuv3 imx-ipuv3.0: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
    [    1.350830] imx-ipuv3 imx-ipuv3.0: WARNING: adapt panel end blank lines
    [    1.384212] Console: switching to colour frame buffer device 160x64
    [    1.432321] mxc_sdc_fb mxc_sdc_fb.1: register mxc display driver ldb
    [    1.438739] _regulator_get: get() with no identifier
    [    1.450405] mxc_sdc_fb mxc_sdc_fb.2: register mxc display driver ldb
    [    1.461584] imx-sdma imx-sdma: loaded firmware 1.1
    [    1.470692] imx-sdma imx-sdma: initialized
    [    1.605377] Serial: IMX driver
    [    1.608593] imx-uart.0: ttymxc0 at MMIO 0x2020000 (irq = 58) is a IMX
    [    1.615487] imx-uart.1: ttymxc1 at MMIO 0x21e8000 (irq = 59) is a IMX
    [    1.621987] console [ttymxc1] enabled, bootconsole disabled
    [    1.633538] imx-uart.3: ttymxc3 at MMIO 0x21f0000 (irq = 61) is a IMX
    [    1.645699] loop: module loaded
    [    1.649242] request BOSSA_CLK IRQ
    [    1.652560] registering IRQ 419 for BOSSAC Arduino erase/reset operation
    [    1.702413] No sata disk.
    [    1.706429] GPMI NAND driver registered. (IMX)
    [    1.711972] vcan: Virtual CAN interface driver
    [    1.716423] CAN device driver interface
    [    1.720278] flexcan netdevice driver
    [    1.724016] FEC Ethernet Driver
    [    1.729478] fec_enet_mii_bus: probed
    [    1.738442] usbcore: registered new interface driver rt2800usb
    [    1.744279] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [    1.750944] fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller
    [    1.757591] fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
    [    1.787495] fsl-ehci fsl-ehci.0: irq 75, io base 0x02184000
    [    1.807473] fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
    [    1.813796] hub 1-0:1.0: USB hub found
    [    1.817577] hub 1-0:1.0: 1 port detected
    [    1.821690] add wake up source irq 72
    [    1.825389] fsl-ehci fsl-ehci.1: Freescale On-Chip EHCI Host Controller
    [    1.832044] fsl-ehci fsl-ehci.1: new USB bus registered, assigned bus number 2
    [    1.877470] fsl-ehci fsl-ehci.1: irq 72, io base 0x02184200
    [    1.907460] fsl-ehci fsl-ehci.1: USB 2.0 started, EHCI 1.00
    [    1.913656] hub 2-0:1.0: USB hub found
    [    1.917420] hub 2-0:1.0: 1 port detected
    [    1.921697] Initializing USB Mass Storage driver...
    [    1.926732] usbcore: registered new interface driver usb-storage
    [    1.932802] USB Mass Storage support registered.
    [    1.937727] usbcore: registered new interface driver usbserial
    [    1.943663] USB Serial support registered for generic
    [    1.948851] usbcore: registered new interface driver usbserial_generic
    [    1.955381] usbserial: USB Serial Driver core
    [    1.959859] USB Serial support registered for debug
    [    1.964860] usbcore: registered new interface driver debug
    [    1.970365] ARC USBOTG Device Controller driver (1 August 2005)
    [    1.976648] g_ether gadget: using random self ethernet address
    [    1.982511] g_ether gadget: using random host ethernet address
    [    1.989102] usb0: MAC 3a:26:d9:ed:27:19
    [    1.992941] usb0: HOST MAC 76:d5:f7:ef:5a:46
    [    1.997217] g_ether gadget: controller 'fsl-usb2-udc' not recognized; trying CDC Ethernet (ECM)
    [    2.005957] g_ether gadget: Ethernet Gadget, version: Memorial Day 2008
    [    2.012592] g_ether gadget: g_ether ready
    [    2.016604] Suspend udc for OTG auto detect
    [    2.020808] USB Host suspend begins
    [    2.020814] will suspend roothub and its children
    [    2.020835] ehci_fsl_bus_suspend begins, DR
    [    2.020857] ehci_fsl_bus_suspend ends, DR
    [    2.020871] host suspend ends
    [    2.020877] USB Gadget resume begins
    [    2.020883] fsl_udc_resume, Wait for wakeup thread finishes
    [    2.037475] dr_controller_run: udc out low power mode
    [    2.037484] USB Gadget resume ends
    [    2.037490] fsl-usb2-udc: bind to driver g_ether
    [    2.042767] mousedev: PS/2 mouse device common for all mice
    [    2.048783] usbcore: registered new interface driver usbtouchscreen
    [    2.055478] Sitronix touch driver 2.9.1
    [    2.059333] Release date: 20120507
    [    2.063143] sitronix_reset_ic
    [    2.186328] send status reg command error (-5)
    [    2.190797] sitronix: probe of 2-0055 failed with error -5
    [    2.196733] i2c-core: driver [isl29023] using legacy suspend method
    [    2.203018] i2c-core: driver [isl29023] using legacy resume method
    [    2.209947] snvs_rtc snvs_rtc.0: rtc core: registered snvs_rtc as rtc0
    [    2.216620] i2c /dev entries driver
    [    2.220912] Linux video capture interface: v2.00
    [    2.247493] usb 2-1: new high speed USB device number 2 using fsl-ehci
    [    2.357558] ov5640_read_reg:write reg error:reg=300a
    [    2.362526] camera ov5640_mipi is not found
    [    2.367130] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video16
    [    2.374781] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video17
    [    2.382461] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video18
    [    2.390102] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video19
    [    2.397754] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video20
    [    2.405539] vivi-000: V4L2 device registered as video2
    [    2.410697] Video Technology Magazine Virtual Video Capture Board ver 0.8.0 successfully loaded.
    [    2.420054] usbcore: registered new interface driver uvcvideo
    [    2.425833] USB Video Class driver (v1.1.0)
    [    2.430719] hub 2-1:1.0: USB hub found
    [    2.430755] i2c-core: driver [mag3110] using legacy suspend method
    [    2.430762] i2c-core: driver [mag3110] using legacy resume method
    [    2.431222] imx2-wdt imx2-wdt.0: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=1)
    [    2.431331] Bluetooth: Virtual HCI driver ver 1.3
    [    2.431561] Bluetooth: HCI UART driver ver 2.2
    [    2.431568] Bluetooth: HCIATH3K protocol initialized
    [    2.431574] Bluetooth: Generic Bluetooth USB driver ver 0.6
    [    2.431712] usbcore: registered new interface driver btusb
    [    2.431868] sdhci: Secure Digital Host Controller Interface driver
    [    2.431874] sdhci: Copyright(c) Pierre Ossman
    [    2.432209] mmc0: SDHCI controller on platform [sdhci-esdhc-imx.2] using DMA
    [    2.497650] hub 2-1:1.0: 4 ports detected
    [    2.497684] mxc_vdoa mxc_vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
    [    2.509154] VPU initialized
    [    2.512517] mxc_asrc registered
    [    2.536983] Thermal calibration data is 0x59350469
    [    2.541792] Thermal sensor with ratio = 185
    [    2.557468] Anatop Thermal registered as thermal_zone0
    [    2.562757] anatop_thermal_probe: default cooling device is cpufreq!
    [    2.571652] usbcore: registered new interface driver usbhid
    [    2.577231] usbhid: USB HID core driver
    [    2.581647] usbcore: registered new interface driver snd-usb-audio
    [    2.588380] mxc_hdmi_soc mxc_hdmi_soc.0: MXC HDMI Audio
    [    2.593829] Cirrus Logic CS42888 ALSA SoC Codec Driver
    [    2.599082] i2c-core: driver [cs42888] using legacy suspend method
    [    2.605266] i2c-core: driver [cs42888] using legacy resume method
    [    2.644648] mmc0: new high speed SDHC card at address e624
    [    2.650552] mmcblk0: mmc0:e624 SS08G 7.40 GiB
    [    2.656292]  mmcblk0: p1
    [    2.693946] audio_codec_ac97_cold_reset
    [    2.757677] USB Gadget resume begins
    [    2.757685] fsl_udc_resume, Wait for wakeup thread finishes
    [    2.780049] Found Audio codec AC97 vt1613, [ID = 5649 - 4123]
    [    2.798271] asoc: vt1613 <-> imx-ssi.0 mapping ok
    [    2.804637] imx_3stack asoc driver
    [    2.809633] asoc: mxc-hdmi-soc <-> imx-hdmi-soc-dai.0 mapping ok
    [    2.816303] ALSA device list:
    [    2.817690] usb 2-1.1: new high speed USB device number 3 using fsl-ehci
    [    2.825981]   #0: vt1613-audio
    [    2.829046]   #1: imx-hdmi-soc
    [    2.832303] NET: Registered protocol family 26
    [    2.837286] TCP cubic registered
    [    2.840530] NET: Registered protocol family 17
    [    2.844987] can: controller area network core (rev 20090105 abi 8)
    [    2.851246] NET: Registered protocol family 29
    [    2.855692] can: raw protocol (rev 20090105)
    [    2.859973] can: broadcast manager protocol (rev 20090105 t)
    [    2.865733] Bluetooth: RFCOMM TTY layer initialized
    [    2.870662] Bluetooth: RFCOMM socket layer initialized
    [    2.875802] Bluetooth: RFCOMM ver 1.11
    [    2.879563] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [    2.884876] Bluetooth: BNEP filters: protocol multicast
    [    2.890111] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
    [    2.896203] lib80211: common routines for IEEE802.11 drivers
    [    2.901878] lib80211_crypt: registered algorithm 'NULL'
    [    2.901886] lib80211_crypt: registered algorithm 'WEP'
    [    2.901892] lib80211_crypt: registered algorithm 'CCMP'
    [    2.901899] lib80211_crypt: registered algorithm 'TKIP'
    [    2.901905] Registering the dns_resolver key type
    [    2.906661] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
    [    2.914706] Bus freq driver module loaded
    [    2.918731] Bus freq driver Enabled
    [    2.924015] mxc_dvfs_core_probe
    [    2.927362] DVFS driver module loaded
    [    2.932679] snvs_rtc snvs_rtc.0: setting system clock to 1970-01-01 00:00:00 UTC (0)
    [    2.943470] EXT3-fs: barriers not enabled
    [    3.327499] usb 2-1.1: device not accepting address 3, error -71
    [    3.427692] usb 2-1.1: new high speed USB device number 4 using fsl-ehci
    [    3.677908] usb 2-1.3: new high speed USB device number 5 using fsl-ehci
    [    3.843729] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
    [    3.845740] Registered led device: rt2800usb-phy0::radio
    [    3.845884] Registered led device: rt2800usb-phy0::assoc
    [    3.846042] Registered led device: rt2800usb-phy0::quality
    [    8.127398] kjournald starting.  Commit interval 5 seconds
    [    8.127503] EXT3-fs (mmcblk0p1): warning: maximal mount count reached, running e2fsck is recommended
    [    8.130182] EXT3-fs (mmcblk0p1): using internal journal
    [    8.130235] ext3_orphan_cleanup: deleting unreferenced inode 131080
    [    8.130306] ext3_orphan_cleanup: deleting unreferenced inode 131079
    [    8.130337] ext3_orphan_cleanup: deleting unreferenced inode 131078
    [    8.130367] ext3_orphan_cleanup: deleting unreferenced inode 131077
    [    8.130397] ext3_orphan_cleanup: deleting unreferenced inode 131076
    [    8.130424] EXT3-fs (mmcblk0p1): 5 orphan inodes deleted
    [    8.130431] EXT3-fs (mmcblk0p1): recovery complete
    [    9.113837] EXT3-fs (mmcblk0p1): mounted filesystem with writeback data mode
    [    9.120937] VFS: Mounted root (ext3 filesystem) on device 179:1.
    [    9.129788] devtmpfs: mounted
    [    9.132811] Freeing init memory: 200K
    [    9.788302] udevd[1647]: starting version 175
    [   11.093192] ERROR: v4l2 capture: slave not found!
    [   11.094469] ERROR: v4l2 capture: slave not found!
    [   16.195157] eth0: Freescale FEC PHY driver [Generic PHY] (mii_bus:phy_addr=1:06, irq=-1)
    [   16.203309] Activating ethernet physical layer Micrel KSZ9031 Gigabit PHY.
    [   19.187852] PHY: 1:06 - Link is Up - 100/Full
    [   38.005147] [drm] Initialized drm 1.1.0 20060810
    [   38.013327] [drm] Initialized vivante 1.0.0 20120216 on minor 0
    [   38.651133] imx-ipuv3 imx-ipuv3.0: WARNING: adapt panel end blank lines
    renthro@udoo-debian-hfp:~$ vi dmesg.log
    So I follow this intructions to enable it on debian
    https://wiki.debian.org/ath9k_htc
    After installing the firmware, I reboot and plugged the dongle and proceed to check that whether the installation had been successful with:
    root@udoo-debian-hfp:~# lsmod
    Module                  Size  Used by
    vivante                  943  1
    drm                   141896  2 vivante
    root@udoo-debian-hfp:~$ modinfo ath9k_htc
    ERROR: Module ath9k_htc not found.
    but it was not found, further checking
    renthro@udoo-debian-hfp:~$ iwconfig
    lo        no wireless extensions.
    eth0      no wireless extensions.
    usb0      no wireless extensions.
    wlan0     IEEE 802.11bgn  Mode:Master  Frequency:2.437 GHz  Tx-Power=20 dBm
              Retry  long limit:7   RTS thr:off   Fragment thr:off
              Power Management:on
    mon.wlan0  IEEE 802.11bgn  Mode:Monitor  Tx-Power=20 dBm
              Power Management:on
    wlan0 is the wifi module that I configured earlier to be used by hostapd running nl80211 driver. I'm planning to use the dongle as a client on another network.
    So any help is really appreciated, thanks.
  2. wgvanveen
    wgvanveen New Member
    Oct 5, 2014
    I have the exact same problem on either Lubuntu and Debian Wheezy. On the raspberry pi the dongle works out of the box. After some research I think it has something to do with the kernel version. So updating Wheezy to a different kernel using backports. However, I am not completely sure how to do this, and if it is the correct awnser. Anybody a clue?
  3. rlagonda
    rlagonda New Member
    Oct 3, 2014
    I suspected that much. I don't have my board atm but my next step would be updating the kernel or trying to compile the ath9k_htc driver using compat wireless driver and load it to kernel. I'll report back when I have it back.
  4. wgvanveen
    Oct 5, 2014
    Did you have some luck? I tried to compile the kernel, but everytime it crashes during the compilation. Also the command:
    make ARCH=arm UDOO_deconfig
    simply doesn't work (no target for UDOO_deconfig). What am I missing here? I did manage to compile the kernel headers, however, backports, compat-drivers or compat-wirless can't seem to install.
  5. rlagonda
    rlagonda New Member
    Oct 3, 2014
    Hi, I finally got it working. Currently I don't have any complete tutorial on doing this, but let me iterate the best way I can.
    Depending on how you configure your kernel, make sure you enable this kernel configuration.
    http://wireless.kernel.org/en/users/Drivers/ath9k_htc#Configuring_your_kernel
    Exclusively to udoo, I think the kernel source from the UDOO's team is a great place to start. I follow this guideline
    http://joshua.solanes.us/operating-system-2/linux-os/2013/12/01/custom-kernel-on-the-udoo/
    Using this kernel configuration tools, I compiled the kernel with ath9k_htc driver opted as modular (M) not included in the kernel. The driver can be found when configuring using
    make menuconfig
    I forgot the exact menu name but It should be fall under "Wireless" or "Network Support" or similar.
    After the configuration is ready, I compiled and loaded the module since I opted to load the driver in modular mode.
    The driver should be listed in
    lsmod
    if we successfully installed that driver.
    After the kernel is compiled and the module is loaded don't forget to install the ath9k_htc firmware
    https://wiki.debian.org/ath9k_htc#Installation
    I didn't use the backported version and installed from the debian main repo.
    apt-get install firmware-atheros
    I think the backported firmware is not necessarily needed, but please feel free to try.
    http://backports.debian.org/Instructions/
    apt-get -t wheezy-backports install firmware-atheros
    This two files should be listed in /lib/firmware after the successful firmware installation
    -rw-r--r-- 1 root root  72992 Jan  6  2013 htc_7010.fw
    -rw-r--r-- 1 root root  51272 Jan  6  2013 htc_9271.fw
    not really sure about this two
    -rw-r--r-- 1 root root  15944 Jan  6  2013 ar9170.fw
    -rw-r--r-- 1 root root  51312 Jan  6  2013 ar9271.fw
    but I also have those.
    And finally modinfo ath9k_htc should return something like this
    filename:       /lib/modules/3.0.35-josolanes-nfsServer-g8a6eb06/kernel/drivers/net/wireless/ath/ath9k/ath9k_htc.ko
    firmware:       htc_9271.fw
    firmware:       htc_7010.fw
    description:    Atheros driver 802.11n HTC based wireless devices
    license:        Dual BSD/GPL
    author:         Atheros Communications
    alias:          usb:v0CF3p20FFd*dc*dsc*dp*ic*isc*ip*
    alias:          usb:v0CF3p9271d*dc*dsc*dp*ic*isc*ip*
    depends:        ath9k_hw,mac80211,ath9k_common,ath,cfg80211
    vermagic:       3.0.35-josolanes-nfsServer-g8a6eb06 SMP mod_unload modversions ARMv7
    parm:           debug:Debugging mask (uint)
    parm:           nohwcrypt:Disable hardware encryption (int)
    Note the firmware being used by the driver, also some ppl directly downloaded the firmware and copied that to /lib/firmware but I guess I'll just have to get whatever the aptitude gave me.
    After that I plugged the device and the dongle indicator is finally turned up.
  6. wgvanveen
    Oct 5, 2014
    Thank you! It was more easy then I thought. I used the following steps:
    First install required packages:
    sudo apt-get install uboot-mkimage  git-core
    Clone the kernel (I didnt use the /usr/src folder, but you can if you like).
    git clone https://github.com/UDOOboard/Kernel_Unico kernel-unico
    Move into the folder
    cd ./kernel-unico
    Make the default .config file
    make ARCH=arm UDOO_defconfig
    Alter the .config by using nano
    nano .config
    And add the following lines at the end of the file (use page down to get there fast).
    CONFIG_ATH_COMMON=m
    CONFIG_ATH9K_HW=m
    CONFIG_ATH9K_COMMON=m
    CONFIG_ATH9K_HTC=m
    Save the file (CTL+X) and run the following command (takes a lot of time)
    make -j5 ARCH=arm uImage modules
    Finally copy the file uImage created in ./arch/arm/boot to the boot location with the following command (some people say you need to backup your old uImage in boot/uImage, I didn't).
    sudo cp -r ./arch/arm/boot/uImage /boot/uImage
    Run the command to copy all new modules into your modules folder.
    sudo make install_modules
    Install the firmware (only works on debian)
    sudo apt-get install firmware-atheros
    Now reboot, and you have a working dongle!
    sambrin likes this.
  7. danrosero
    danrosero New Member
    Sep 5, 2014
    Hi, im currently thinking in getting the Tl-wn722n usb dongle so I can Ad-hoc.
    Does this procedure will work on the UDOObuntu O.S?
    Thanks
  8. sirrab
    sirrab UDOOer
    Jul 26, 2014
    264
    32
    Why does this stuff create boot images for all the architectures? No wonder it takes forever! And I didn't see a uImage file. There is Image and ZImage files. These are questions for the UDOO developement team, I suspect......
  9. adragon202
    adragon202 New Member
    Aug 14, 2015
    I have two problems with this.
    1. This line doesn't work.
    I install_modules doesn't exist, however modules_install does. So I use
    sudo make modules_install
    2. System reboots, shows the UDOO logo, then goes to a blank screen and will not progress from there.
    ******UPDATE*******
    Turns out the issue I'm having is already listed as an issue on github.
    https://github.com/UDOOboard/Kernel_Unico/issues/10
    Ended up crosscompiling the kernel using these instructions.
    http://www.udoo.org/docs/Advanced_Setup/Compile_The_Linux_Kernel_And_The_Modules
    I then used scp to transfer the new uImage and lib directory from the build machine to the UDOO.
