Issue with wlan0 not able to connect
Discussion in 'UDOO NEO' started by oxoocoffee, Oct 18, 2016.
  1. oxoocoffee
    oxoocoffee Member
    Sep 13, 2016
    57
  2. cyrilf
    cyrilf Active Member
    Feb 19, 2015
    168
    47
    Your can see all the dependencies with bitbake:
    bitbake -g udoo-image-full-cmdline -u depexp
    Which package manager are you using?
  3. oxoocoffee
    oxoocoffee Member
    Sep 13, 2016
    57
    Just to let you know I was trying to build this on new freshly installed 16.04 server and at some point I got error that python was not installed. Not sure if you do check for prerequisites .... but if you do can you add python?
  4. oxoocoffee
    oxoocoffee Member
    Sep 13, 2016
    57
    Ok So I started fresh build just some time ago and I got this error message after some time building. I am building on 1604LTS server with latest updates.
    NOTE: Fetching uninative binary shim from http://downloads.yoctoproject.org/r...da6426197d36358bf7b4e88e552ef933128498c8910f8
    NOTE: Preparing RunQueue
    NOTE: Executing SetScene Tasks
    NOTE: Executing RunQueue Tasks
    ERROR: linux-udooboard-3.14.56-r0 do_patch: Command Error: 'quilt --quiltrc /home/rob/Yocto/udoo-yocto-base/poky/build/tmp/sysroots/x86_64-linux/etc/quiltrc push' exited with 1 Output:
    Applying patch 0020-udooneo-enable-ecspi2.patch
    patching file arch/arm/boot/dts/imx6sx-udoo-neo-externalpins.dtsi
    Hunk #3 FAILED at 162.
    1 out of 3 hunks FAILED -- rejects in file arch/arm/boot/dts/imx6sx-udoo-neo-externalpins.dtsi
    Patch 0020-udooneo-enable-ecspi2.patch does not apply (enforce with -f)
    ERROR: linux-udooboard-3.14.56-r0 do_patch: Function failed: patch_do_patch
    ERROR: Logfile of failure stored in: /home/rob/Yocto/udoo-yocto-base/poky/build/tmp/work/udooneo-poky-linux-gnueabi/linux-udooboard/3.14.56-r0/temp/log.do_patch.16965
    ERROR: Task 51 (/home/rob/Yocto/udoo-yocto-base/poky/meta-udoo/recipes-kernel/linux/linux-udooboard_3.14.56.bb, do_patch) failed with exit code '1'
    NOTE: Tasks Summary: Attempted 996 tasks of which 0 didn't need to be rerun and 1 failed.
    Waiting for 0 running tasks to finish:
    Summary: 1 task failed:
    Summary: There was 1 WARNING message shown.
    Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
    Any ideas?
  5. cyrilf
    Feb 19, 2015
    168
    47
    I do not check for prerequisites as BitBake normally do.
    Did you try to clean your image?
    bitbake -c cleanall udoo-image-full-cmdline
    bitbake udoo-image-full-cmdline
    It seems that the ecspi2 patch needs to be updated...
  6. oxoocoffee
    oxoocoffee Member
    Sep 13, 2016
    57
    Ok so I did clean pull and build. I got same issue as I reported. So then I did try
    And got this again
    ERROR: Logfile of failure stored in: /home/rob/Yocto/udoo-yocto-base/poky/build/tmp/work/udooneo-poky-linux-gnueabi/linux-udooboard/3.14.56-r0/temp/log.do_patch.26024
    NOTE: Tasks Summary: Attempted 1007 tasks of which 998 didn't need to be rerun and 1 failed.
  7. cyrilf
    Feb 19, 2015
    168
    47
    I have to update the "0020-udooneo-enable-ecspi2.patch" patch that enable the SPI bus in the
    imx6sx-udoo-neo-externalpins.dtsi file.
  8. oxoocoffee
    oxoocoffee Member
    Sep 13, 2016
    57
    S
    Sure thing. Let me know when you get to it and I will give it a try again.
    Thank you for all your help!!!!
  9. cyrilf
    Feb 19, 2015
    168
    47
    I updated the repo.
    cd udoo-yocto-base
    source sync.sh
    cd poky/build
    bitbake -c cleanall linux-udooboard
  10. oxoocoffee
    oxoocoffee Member
    Sep 13, 2016
    57
    Thank you. Just started the build. Will let you know in a few
    UPDATE: I was able to build with out any errors. Will give it a spin in a few.
    cyrilf likes this.
  11. oxoocoffee
    oxoocoffee Member
    Sep 13, 2016
    57
    Ok... So image was build on Ubuntu 16.04 LTS and it did booted from SD card just fine.
    So Thank You Very Much for your help and support!!!!
    After reading some Yocto documentation I wanted to change couple of things. Since I am just starting rebuilding the image each time takes some time :)
    1. I am trying to remove root login and replace with udooer/uddoer. So I did edited udoo-yocto-base/conf/local.conf and added following below. But what I am still trying to figure out is uncomment
    %sudo section in /etc/sudoers or echo this from build script to /etc/sudoers
    INHERIT += "extrausers"
    EXTRA_USERS_PARAMS = "\
    useradd -p udooer udooer; \
    usermod -s /bin/bash; \
    groupmod -a -G sudo udooer; \
    EDIT: After building with above and logging as root I see that udooer exists in
    shado, passwd and group. But the password is not set in shadow...
    Also groupmod -a -G sudo udooer did not take effect and udooer was not added
    to sudo group. Hmmm
    2. Disable root access (want to know what are the options to do this)
    a. All root access (tty/serial/serial). I think this is by removing debug-tweaks
    or b. All access except when connecting over serial
    3. I was trying to add following packages that I use all the time
    tcpdump, htop, bmon, iptraf, gpgv
    I did try to add them to EXTRA_IMAGE_FEATURES but this gave me error. Now I am reading perhaps better option is IMAGE_INSTALL_append = " htop"? One for each above?
    4. For development version I am building tools-sdk tools-profile tools-debug. Still will do cross compile most of the time but it might be useful at times to have these tools on board. I am not clear what is the purpose of dev-pkgs
    5. If baking non development version where no development tools are needed I am thinking about empty EXTRA_IMAGE_FEATURES. That sounds ok?
    6. I was trying to add ROS.org repo to cooked image and I got error that gpgv was not found.
    If anyone can help thank you....
  12. oxoocoffee
    oxoocoffee Member
    Sep 13, 2016
    57
    So I found on your side http://www.udoo.org/other-resources/ section to get and build kernel. One obvious part is that clicking on "How To Compile The Kernel Sources" produces 404 Page not found.
    [Support]
    Also wondering if you have any plans to release updated minimal to have working WIFI?
    [cyrilif]
    Thank you for all your steps and help. This is great learning for me!!! But I have to plow with other tasks and I am looking for something that I can just install, has proper apt-get/ppa, WIFI, no root login enabled and no desktop. At this time to continue I think I might go with desktop version and just uninstall various packages.
  13. oxoocoffee
    oxoocoffee Member
    Sep 13, 2016
    57
    I was able to rebuild minimal from source and I got WIFI working!!!
    EDIT: Actually I did go back to udoo neo minimal released version and I got WIFI working.
    Looks like the problem from other posts was improper driver loaded.
    Would it be possible to add this to next official minimal build?
    cat /etc/network/interface
    # Wireless interfaces
    allow-hotplug wlan0
    iface wlan0 inet dhcp
            wireless_mode managed
            wireless_essid any
            wpa-driver nl80211
            wpa-conf /etc/wpa_supplicant.conf
    Also add default template to
    cat /etc/wpa_supplicant.conf
    ctrl_interface=/var/run/wpa_supplicant
    ctrl_interface_group=0
    update_config=1
    network={
         ssid="TOP-SECRET"
         scan_ssid=1
         proto=WPA
         key_mgmt=WPA-PSK
         pairwise=TKIP
         group=TKIP
         psk="Insert your top secret key here"
    After ssid and psk was set just reboot and then issue
       ifup wlan0
    or
       ifconfig wlan0 up
