kernel issue? <random: nonblocking pool...>
Discussion in 'Troubleshooting' started by Giuseppe D'Alessandro, Nov 5, 2020.
  1. Giuseppe D'Alessandro
    Giuseppe D'Alessandro New Member
    Nov 5, 2020
    Dear all,
    My UDOO-quad was turned off a lot of time. I created a new bootable microSD with UDOObuntu LTS this morning and when I turned on the board, I read this via serial connection:
    What's the problem?
    Thank you in advance
    U-Boot 2015.10-00061-g68849f9 (Jan 08 2016 - 17:01:43 +0100)
    CPU: Freescale i.MX6Q rev1.2 at 792 MHz
    Reset cause: POR
    Board: UDOO Quad
    DRAM: 1 GiB
    MMC: FSL_SDHC: 0
    *** Warning - bad CRC, using default environment
    No panel detected: default to HDMI
    Display: HDMI (1024x768)
    In: serial
    Out: serial
    Err: serial
    Net: using phy at 6
    FEC [PRIME]
    Hit any key to stop autoboot: 0
    switch to partitions #0, OK
    mmc0 is current device
    reading uEnv.txt
    52 bytes read in 10 ms (4.9 KiB/s)
    Running bootscript from mmc ...
    Device Tree: dts/imx6q-udoo-hdmi.dtb
    reading zImage
    4546472 bytes read in 234 ms (18.5 MiB/s)
    Booting from mmc ...
    reading dts/imx6q-udoo-hdmi.dtb
    41714 bytes read in 24 ms (1.7 MiB/s)
    Kernel image @ 0x12000000 [ 0x000000 - 0x455fa8 ]
    ## Flattened Device Tree blob at 18000000
    Booting using the fdt blob at 0x18000000
    Using Device Tree in place at 18000000, end 1800d2f1
    Starting kernel ...
    [ 0.000000] Booting Linux on physical CPU 0x0
    [ 0.000000] Linux version 3.14.56-udooqdl-02015-g8c051b6 (udooer@udoo) (gcc version 4.8.4 (Ubuntu/Linaro 4.8.4-2ubuntu1~14.04.1) ) #2 SMP PREEMPT Wed Apr 27 11:37:54 UTC 2016
    [ 2.427522] random: nonblocking pool is initialized
    After several time (less then 20min):
    [ 602.283765] mmc0: Card stuck in programming state! mmcblk0 mmc_blk_err_check
    [ 602.290909] end_request: I/O error, dev mmcblk0, sector 67584
    [ 602.296683] Buffer I/O error on device mmcblk0p2, logical block 0
    [ 602.302781] lost page write due to I/O error on mmcblk0p2
    [ 602.308212] end_request: I/O error, dev mmcblk0, sector 67592
    [ 602.313980] Buffer I/O error on device mmcblk0p2, logical block 1
    [ 602.320078] lost page write due to I/O error on mmcblk0p2
    [ 612.343802] mmc0: Timeout waiting for hardware interrupt.
    [ 612.349250] ------------[ cut here ]------------
    [ 612.353911] WARNING: CPU: 0 PID: 0 at drivers/mmc/host/sdhci.c:997 sdhci_send_command+0xc50/0xdf8()
    [ 612.363800] ---[ end trace 8bdab3ec4231f21b ]---
    [ 612.368729] mmcblk0: error -110 sending stop command, original cmd response 0x0, card status 0x400f00
