Neo Basic M4 I2C detect
Discussion in 'UDOO NEO' started by Gary Huband, Sep 8, 2016.
  1. Gary Huband
    Gary Huband New Member
    Aug 1, 2016
    22
    The below code to detect I2C devices (MCP3424 ADC) on arduino like micro-controllers works perfectly on an Arduino Uno R3 and a Teensy 3.2, but when run on the M4 shows that all addresses have a device connected. Why doesn't this work on the Neo? Do I need to do some special setup on the Neo (hardware and/or software)? I can successfully read the MCP3424 from the M4 when connected to I2C2 on the Neo.
    Thanks in advance.
    The code is from Steve Marple's github MCP342X library.
    #include <Wire.h>
    void setup(void)
      Serial.begin(115200);
      Wire.begin();
      Serial.println("The MCP3422 and MCP3426 use I2C address 0x68, all other devices can be");
      Serial.println("configured to use any address in the range 0x68 - 0x6F (inclusive).");
      Serial.println("Be aware that the DS1307 uses address 0x68.");
      Serial.println();
      for (uint8_t add = 0X68; add < 0X6F; add++) {
        //Serial.print("Trying ");
        //Serial.println(add);
        Wire.requestFrom(add, (uint8_t)1);
        if (Wire.available()) {
          Serial.print("Found device at: 0x");
          Serial.println(add, HEX);
      Serial.println("Done");
    void loop(void)
  2. ektor5
    Jul 1, 2013
    97
    48
    Hi there Gary,
    If you are using SCL/SDA pins, maybe you better use Wire1 instead of Wire.
    Let me know,
    Ek5
  3. Gary Huband
    Aug 1, 2016
    22
    No, Wire1 did not work.
  4. ektor5
    Jul 1, 2013
    97
    48
    If you use Wire, you'll talk with the Brick Connector, that is connected also with A9. If you've also enabled the i2c on A9 via Device Tree Editor, you'll have 2 master devices on the same bus. This will result in a faulty behavior.
  5. Gary Huband
    Aug 1, 2016
    22
    The Neo Doc under Arduino M4 Processor, Arduino differences says:
    UDOO Neo M4 Processor has 2 I2C buses wired to the pinout headers and consequentially have 2 Wire objects:
    • Wire: on Brick Connector
    • Wire1: on SCL SDA pins
    Be careful and double check when calling Wire.begin() or Wire1.begin() in sketches or libraries. Also check out to have I2C-2 disabled on A9 if you use Wire.
    So to use the I2C on the M4 I have to:
    - Remove I2C-2 from the bricks connector using the Device Tree Editor (the linux side will not have access to I2C-2)
    - Reboot
    - If I use SCL and SDA on the Arduino header then I should always use Wire1.
    - If I want to access the bricks connector from the M4 then I use Wire.
    Is this correct?
    Can someone post example code for reading an I2C device from the M4?
    Thanks
