Hi, I performed an: $ sudo apt-get update followed by $ sudo apt-get upgrade Then I rebooted the device, and it would not boot up. The red and yellow lights on the board stayed steady, and it was unaccessible over the network. I flashed the SD card back to before the upgrade, and it's working again. Is this an expected issue?
No, this is not an expected issue. It's unexpected. Thanks a lot for having highlighted this problem.
Same thing happened to me...repeatable (four times). The last time, I did: setup SD, boot to udoo, setup WiFi password, reboot. That worked (I wanted to confirm I could reboot at all, without doing apt-get stuff!) Rebooted ok. This means the distro image *can* reboot! Did apt-get update, apt-get upgrade NOTE: got error in 'upgrade': ...did a second "apt-get upgrade" which completed with no errors. did 'sync' tried: reboot ... wouldn't come up. repeated above, and then tried "shutdown -h" followed by a power cycle ... wouldn't come up. Note: not sure about first two tests, but in the last two tests (i.e., create SD image, do initial bootup, setup wifi, do apt-get update / apt-get upgrade) I got the dpkg error each time. On another thread somewhere, someone suggested doing: dpkg --add-architecture armhf I did it, but it wasn't a clean/good/valid test (because I'd already done one attempt at apt-update), and the subsequent reboot failed. If I get ambitious, I'll do a new image, boot to it, do the 'add', then try apt-get update/upgrade and see what happens.[/QUOTE]
Same here, Flash SD on Linux, then apt-get update & apt-get upgrade as first thing done. Boot failed. Repeated couple times, always same reuslt, I thing the Linux-image is somehow broken
> If I get ambitious, I'll do a new image, boot to it, do the 'add', then try apt-get update/upgrade and see what happens.[/QUOTE][/QUOTE] I tried again, first doing the dkpg add-architecture, then apt-get update , apt-get upgrade, reboot ... failed.
Based on some past (bad) experiences with other small board computers, I re-imaged the SD, booted up, copied over about 1000 files of C source code / headers / etc, and compiled about 500 programs ... heavy disk activity, and the system later rebooted with no problem. (I'd wondered if the problem was with the file system, and the "apt-get" was overwriting the end somehow ... but now I doubt that possibility.)
Dear folks, now sudo apt-get update or sudo apt-get upgrade shouldn't hang the board anymore. Could you try it and tell us if it works for you or not?
Same result (failure to bootup) for me. Of possible interest are the errors reported by apt-get upgrade: (See the lines above text "SEE ABOVE") root@udooneo:~# apt-get update Hit http://repository.udoo.org udoobuntu InRelease ... Hit http://ports.ubuntu.com trusty/universe Translation-en Reading package lists... Done root@udooneo:~# root@udooneo:~# apt-get upgrade Reading package lists... Done Building dependency tree Reading state information... Done Calculating upgrade... Done The following packages will be upgraded: gir1.2-vte-2.90 krb5-locales libdrm-dev libdrm-exynos1 libdrm-freedreno1 libdrm-nouveau2 libdrm-omap1 libdrm-radeon1 libdrm2 libgssapi-krb5-2 libido3-0.1-0 libk5crypto3 libkrb5-3 libkrb5support0 libnautilus-extension1a libnspr4 libnss3 libnss3-nssdb libvte-2.90-9 libvte-2.90-common linux-firmware-image-3.14.28-udooneo linux-image-3.14.28-udooneo nautilus-data udooneo-bluetooth unity-settings-daemon unzip xserver-common xserver-xorg-core xserver-xorg-dev The following packages will be DOWNGRADED: linux-dtb-3.14.28-udooneo 29 upgraded, 0 newly installed, 1 downgraded, 0 to remove and 0 not upgraded. Need to get 13.3 MB of archives. After this operation, 2,252 kB disk space will be freed. Do you want to continue? [Y/n] y Get:1 http://repository.udoo.org/ udoobuntu/main libdrm-dev armhf 2.4.60-2~ubuntu14.04.2-udoo [139 kB] Get:2 http://ports.ubuntu.com/ubuntu-ports/ trusty-updates/main libk5crypto3 armhf 1.12+dfsg-2ubuntu5.2 [75.9 kB] ... Get:29 http://repository.udoo.org/ udoobuntu/main xserver-xorg-core armhf 2:1.15.1-0ubuntu2.7udoo [982 kB] Get:30 http://repository.udoo.org/ udoobuntu/main xserver-xorg-dev armhf 2:1.15.1-0ubuntu2.7udoo [290 kB] Fetched 13.3 MB in 11s (1,176 kB/s) (Reading database ... 105557 files and directories currently installed.) Preparing to unpack .../libk5crypto3_1.12+dfsg-2ubuntu5.2_armhf.deb ... Unpacking libk5crypto3:armhf (1.12+dfsg-2ubuntu5.2) over (1.12+dfsg-2ubuntu5.1) ... Preparing to unpack .../libgssapi-krb5-2_1.12+dfsg-2ubuntu5.2_armhf.deb ... Unpacking libgssapi-krb5-2:armhf (1.12+dfsg-2ubuntu5.2) over (1.12+dfsg-2ubuntu5.1) ... ... Preparing to unpack .../libnautilus-extension1a_1%3a3.10.1-0ubuntu9.11_armhf.deb ... Unpacking libnautilus-extension1a (1:3.10.1-0ubuntu9.11) over (1:3.10.1-0ubuntu9.9) ... Preparing to unpack .../linux-image-3.14.28-udooneo_04206-g9e7d486_armhf.deb ... Unpacking linux-image-3.14.28-udooneo (04206-g9e7d486) over (04196-gb15f827) ... dpkg: error processing archive /var/cache/apt/archives/linux-image-3.14.28-udooneo_04206-g9e7d486_armhf.deb (--unpack): trying to overwrite '/boot/dts/imx6sx-udoo-neo-hdmi.dtb', which is also in package linux-dtb-3.14.28-udooneo 04196-gb15f827 dpkg-deb: error: subprocess paste was killed by signal (Broken pipe) dpkg: warning: downgrading linux-dtb-3.14.28-udooneo from 04196-gb15f827 to 1.0-1 SEE ABOVE Preparing to unpack .../linux-dtb-3.14.28-udooneo_1.0-1_all.deb ... Unpacking linux-dtb-3.14.28-udooneo (1.0-1) over (04196-gb15f827) ... Preparing to unpack .../linux-firmware-image-3.14.28-udooneo_04204-ge2a34ed_armhf.deb ... Unpacking linux-firmware-image-3.14.28-udooneo (04204-ge2a34ed) over (04196-gb15f827) ... Preparing to unpack .../nautilus-data_1%3a3.10.1-0ubuntu9.11_all.deb ... Unpacking nautilus-data (1:3.10.1-0ubuntu9.11) over (1:3.10.1-0ubuntu9.9) ... Preparing to unpack .../udooneo-bluetooth_1.2_armhf.deb ... UIM SYSFS Node Found at /sys/./devices/soc0/kim.21/install Stopping uim-sysfs daemon. Unpacking udooneo-bluetooth (1.2) over (1.1) ... Preparing to unpack .../unity-settings-daemon_14.04.0+14.04.20151012-0ubuntu1_armhf.deb ... ... Processing triggers for hicolor-icon-theme (0.13-1) ... Processing triggers for mime-support (3.54ubuntu1.1) ... Errors were encountered while processing: /var/cache/apt/archives/linux-image-3.14.28-udooneo_04206-g9e7d486_armhf.deb E: Sub-process /usr/bin/dpkg returned an error code (1) SEE ABOVE root@udooneo:~# sync root@udooneo:~# sync root@udooneo:~# reboot
I got same erroe while I upgrade as sieler described. --snip-- Processing triggers for mime-support (3.54ubuntu1.1) ... Errors were encountered while processing: /var/cache/apt/archives/linux-image-3.14.28-udooneo_04206-g9e7d486_armhf.deb E: Sub-process /usr/bin/dpkg returned an error code (1) But I run again update and upgrade, the error has gone.
sieler, Do you try reboot by command?. my neo is booting successfully after I reset the power. how about your neo?
Kevin...did your reboot succeed *after* doing an "apt-get update" and then "apt-get upgrade"? (No one else reporting on the thread had that success) I've tried the reset button, 'reboot' command, and power cycling ... I've done the killer "apt-get upgrade" about 8 times now, with different variations of other things (e.g., with/without a sync, a dpkg add, or other compilation / file system work)). The only time any reboot succeeds is if I have not yet done an "apt-get upgrade". Prior to the 'upgrade', things work. After the upgrade, no reboot of any kind works.
That's interesting. In my case, yes, I tried reboot by command at the first time. but neo was pending to reboot. So, I plug off and plug in the power. That's all I have done. udooer@udooneo:/etc$ cat os-release NAME="Ubuntu" VERSION="14.04.3 LTS, Trusty Tahr" ID=ubuntu ID_LIKE=debian PRETTY_NAME="Ubuntu 14.04.3 LTS" VERSION_ID="14.04" HOME_URL="http://www.ubuntu.com/" SUPPORT_URL="http://help.ubuntu.com/" BUG_REPORT_URL="http://bugs.launchpad.net/ubuntu/" udooer@udooneo:/etc$ uname -a Linux udooneo 3.14.28-udooneo-04206-g9e7d486 #31 SMP PREEMPT Thu Nov 12 16:22:15 CET 2015 armv7l armv7l armv7l GNU/Linux udooer@udooneo:/etc$
thanks.... this thread is specifically about something you haven't tried yet (I.e., apt-get update followed by apt-get upgrade, followed by reboot)
Hi, I had the same error after apt-get upgrade. I did a reboot command and the neo hadn't came up. after a button reboot neo is up and running. greetz
I somehow managed it by apt-get update apt-get upgrade, then install mc( for seeing logs), the apt-get update and apt-get upgrade and reboot worked. I dont know why, maybe I was just lucky
