Udoo quad Debian and Ubuntu image with 4.4.20 and 3.14.79 / 16.9.2016
Discussion in 'Debian' started by igorpec, Mar 7, 2015.
  1. igorpec
    igorpec UDOOer
    Jan 25, 2015
    28
    13
    Hi people. Quite some time ago I created a script for general kernel compilation and image creation for ARM boards that are scattered around my desk ;) Recently I added support for Udoo Quad and you are able to compile your own kernel / image if you like or need to.
    [​IMG]
    Build process is based on this kernel (great work!) with my own configuration and minor modifications.
    Available for download:
    Debian Wheezy, Jessie and Ubuntu Trusty.
    v5.2
    http://docs.armbian.com/Release_Changelog/
    v1.5.2016
    - 4.4.8 and 3.14.67
    - docker ready
    v1.9 / 6.8.2015
    Kernel 4.0.8 with working analogue audio
    Added desktop image
    Added auto kernel / system update via repository apt.armbian.com
    Root password change is initialized at first boot.
    v1.8 / 13.7.2015
    Kernel 4.0.8
    v1.7 / 17.5.2015
    Kernel 3.18.13
    Ubuntu and jessie install errors fixed, removed busybox-syslogd and changed to default logger due to problems in Jessie and Ubuntu, apt-get upgrade fixed, documentations update
    Build script rework – image size shrink to actual size, possible to have fat boot partition on SD card, several script bug fixes
    v1.6 / 20.4.2015
    Kernel 3.18.11
    Added Jessie and Ubuntu Trusty
    apt-get upgrade ready but not enabled yet, serial console fixed, fixed hostapd under jessie, easy kernel switching, latest patched hostapd for best performance – normal and for realtek adaptors, auto IO scheduler script
    Build script: everything packed as DEB
    Summary:
    • Build ready – possible to compile external modules.
    • Eth and Wifi operational
    • Many performance tweaks
    Details:
    • Ethernet adapter with DHCP and SSH server ready on default port (22) with regenerated keys @ first boot
    • Wireless adapter with DHCP ready but disabled (/etc/network/interfaces, WPA2: normal connect, bonding / notebook or AP mode). It can handle between 40-70Mbit/s.
    • SATA operational
    • Enabled HDMI audio device
    • Bluetooth ready (working with external key)
    • root file-system auto resize
    • Graphics desktop environment upgrade ready
    • Serial console enabled
    • Enabled automatic security updating
    • Login script shows Udoo MOTD, hard drive temp, ambient temp from Temper if exits & actual free memory
    • root password=1234 and expires at first login
    Performance tweaks:
    • /tmp & /log = RAM, ramlog app saves logs to disk daily and on shut-down.
    • IO scheduler NOOP for SD. (change in /etc/sysfs.conf)
    • journal data writeback enabled. (/etc/fstab)
    • commit=600 to flush data to the disk every 10 minutes (/etc/fstab)
    Bugs or limitations
    • Exists. :) :( Please report that we can fix them.
    Download
    patrykk and Guilherme Strube like this.
  2. sirrab
    sirrab UDOOer
    Jul 26, 2014
    264
    32
    Udoo quad Debian SD image with 3.18.x
    Very cool!
  3. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    Amazing ! I will test it this week and let you know ! Thank's for it ;)
  4. Keridos
    Keridos New Member
    Nov 19, 2013
    22
    Hi there,
    I just took your kernel and put it into an older installation of debian wheezy I have installed. But for some reason OpenGL acceleration does not seem to work. What could cause that?
  5. patrykk
    patrykk Member
    Dec 10, 2014
    52
    Re: Udoo quad Debian SD image with 3.18.x
    Hi Igor: please update kernel to last from my repo. I resolved bug related to VPU.
    Keridos: You need new binaries from freescale for kernel 3.10.53-ga :
    libcec-imx6 13.20141201
    imx-lib 3.10.53_1.1.0
    imx-vpu 5.4.27-1
    firmware-imx 3.10.31_1.1.0
    imx-gpu-viv-g2d 5.0.11.p4.1 (previous name: gpu-viv-g2d)
    imx-gpu-viv-(x11|fb) 5.0.11.p4.1 (previous name: gpu-viv-bin-mx6q)
    libfslvpuwrap 1.0.57
    best regards,
  6. Keridos
    Keridos New Member
    Nov 19, 2013
    22
    Ok, so I need to manually compile them or can I just apt-get them?
  7. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    Yesterday i tried uour debian version. First boot all works but after i install a desktop environment :
    apt-get -y install xorg lightdm xfce4 xfce4-goodies tango-icon-theme gnome-icon-theme
    reboot
    after that i just have a box where i write my login and password. Then, i only have a terminal ! I don't have any desktop ! This is normal ?
  8. mocho
    mocho New Member
    Mar 14, 2015
    First of all thanks for your work.
    Second just to tell you that tried ubuntu and it did not work. I could compile, write image to sd card, but nothing happens. not even grub info.
    third. you say your image is bluetooth ready with external key, but I tryed 3 or 4 diferent keys and all i am getting is
    root@udoo:~# /etc/init.d/bluetooth start
    [....] Starting bluetooth: bluetoothd rfcommCan't open RFCOMM control socket: Address family not supported by protocol
    . ok
    I can not start bluetooth
    Also, I can mount an usb ext3 disk trough mount command but it offens fails trough fstab
    root@udoo:~# mount -a
    mount: wrong fs type, bad option, bad superblock on /dev/sda1,
           missing codepage or helper program, or other error
           In some cases useful info is found in syslog - try
           dmesg | tail  or so
    regards
  9. igorpec
    igorpec UDOOer
    Jan 25, 2015
    28
    13
    Yes, this is normal. Those instructions are for quick / basic / essential / minimal desktop, more as a prove that it's possible. I leave desktop upgrade open to you since this is also a border line for me to keep focus on real problems.
    From this point is the same as on any Debian / Ubuntu.
  10. igorpec
    igorpec UDOOer
    Jan 25, 2015
    28
    13
    I can't comment why Ubuntu compilation wasn't successful. There are way too many things that can go wrong and I also never try to compile Ubuntu for Udoo. I plan to add Jessie / Trusty when we fix most of problems including Bluetooth. I guess I need to re-check configuration. Thanks for feedback.
  11. igorpec
    igorpec UDOOer
    Jan 25, 2015
    28
    13
    Yes, I just put out a new compilation. Essentials are working, now testing and since I forget to fix Bluetooth there will be an update soon.
  12. Keridos
    Keridos New Member
    Nov 19, 2013
    22
    Udoo quad Debian SD image with 3.18.x / 14.3.2015
    Hm, I have an issue, i used my old chroot to build the stuff, copied the new kernel headers from the repository you specified via
    make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- INSTALL_HDR_PATH=../xbmc-build/usr/src/linux headers_install
    But on compiling imx-lib I get the issue that
    pxp_lib.h:19:30: fatal error: linux/pxp_device.h: No such file or directory
    What did I do wrong there?
    Or can I just fetch the binaries from your image somehow?
  13. mmeinert
    mmeinert Member
    Jun 17, 2014
    61
    Re: Udoo quad Debian SD image with 3.18.x / 14.3.2015
    Great work !
    Will test 1.4 this weekend :)
    Thank you
  14. mocho
    mocho New Member
    Mar 14, 2015
    Re: Udoo quad Debian and Ubuntu image with 3.18.x / 20.4.201
    Thank you!
    Best image for Udoo by far, the ones that are in download area are crap, don't even have bridge suport in kernel.
  15. punk45rock
    punk45rock Member
    Dec 21, 2013
    32
    Hi is it possible to access the arduino with this image? I have been trying with the instructions in jas-mx Debian Jessie thread but the arduino ide says it can't find gpio pins.
  16. patrykk
    patrykk Member
    Dec 10, 2014
    52
    You could use arduino from serial and Arduino IDE level under this kernel. Just read README for 3.18 unofficial udoo kernel:
    https://github.com/patrykk/linux-udoo/blob/3.18/README.md
    "Arduino with Udoo patch (export gpio 0 and 117: "echo 0 > /sys/class/gpio/export; echo 117 > /sys/class/gpio/export")"
    @Igor: Please create some howto for yours users.
  17. punk45rock
    punk45rock Member
    Dec 21, 2013
    32
    Thanks, have got the gpio stuff working, i could blink an led on gpio40 and i have got systemd enabling pins gpio0 and gpio117 at boot. my only problem now is the arduino reports "no device found on ttymxc3" after chmod 777 on /dev/ttymxc3 and chgrp -R dialout /sys/class/gpio. it also spits the same error if i just try running the ide as root. i have also tried using the patched bossac and followed directions for arduino ide in jas-mx debian post.
  18. patrykk
    patrykk Member
    Dec 10, 2014
    52
    Hm, It sounds like some problem with latest kernels but could you confirm that you couldn't reflash cpu via arduino IDE ?
  19. patrykk
    patrykk Member
    Dec 10, 2014
    52
  20. punk45rock
    punk45rock Member
    Dec 21, 2013
    32
    Fantastic, thank you. I will have a go at compiling the kernel over the weekend.
