Hi, that is very nice. Btw: I am using this and added meta-qt5 to add support for the current qt5 version. Is there any plan to make a layer for the current yocto revision? Has anyone tried that? Whould that be possible with the old kernel 3.0.35?
chrta, it's possible for you to post some image of udoo under yocto ? Do you use udooquad ? Is it possible to use sata disque and touchscreen under yocto ? Is-it possible for udooTeam to update the image image of yocto (on the site) with the portage of Isronga ? and great job Isronga !!!
can you said me how many times is needed to compile yocto ? Another thing, if i try try to build the image with qt (bitbake fsl-core-gui) i obtained this error : Code: Parsing of 1346 .bb files complete (0 cached, 1346 parsed). 1739 targets, 80 skipped, 0 masked, 0 errors. ERROR: Nothing PROVIDES 'fsl-core-gui'. Close matches: fsl-image-gui Do you know what ? If i want to compile qt5, i need to integrate the qt5 meta layer : https://github.com/meta-qt5/meta-qt5 in Code: yocto /sources ? After that, i need to add Code: ${BSPDIR}/sources/meta-qt5 \ in Code: yocto/build/conf/bblayers.conf ? Please, let me know if this is ok :roll:
Ok, i have build with success the minimal of yocto image (in 4 hours). Now i 'm trying to compile the full image with qt 5 (i downloaded with git into yocto/sources the meta layer for qt5 (https://github.com/meta-qt5/meta-qt5.git). My BBlayers.conf (into yocto/build/conf/ directories) : Code: LCONF_VERSION = "6" BBPATH = "${TOPDIR}" BSPDIR := "${@os.path.abspath(os.path.dirname(d.getVar('FILE', True)) + '/../..')}" BBFILES ?= "" BBLAYERS = " \ ${BSPDIR}/sources/poky/meta \ ${BSPDIR}/sources/poky/meta-yocto \ \ ${BSPDIR}/sources/meta-openembedded/meta-oe \ \ ${BSPDIR}/sources/meta-fsl-arm \ ${BSPDIR}/sources/meta-fsl-arm-extra \ ${BSPDIR}/sources/meta-ronga-udoo \ ${BSPDIR}/sources/meta-fsl-demos \ ${BSPDIR}/sources/meta-qt5 \ " my path where is yocto : /media/modjo/39a50e93-4c35-4598-a6b8-9627986411e5/yocto/ When i try : $ bitbake fsl-core-gui i obtain this errors : Code: ERROR: Traceback (most recent call last): File "/media/modjo/39a50e93-4c35-4598-a6b8-9627986411e5/yocto/fsl-community-bsp/sources/poky/bitbake/lib/bb/cookerdata.py", line 162, in wrapped return func(fn, *args) File "/media/modjo/39a50e93-4c35-4598-a6b8-9627986411e5/yocto/fsl-community-bsp/sources/poky/bitbake/lib/bb/cookerdata.py", line 172, in parse_config_file return bb.parse.handle(fn, data, include) File "/media/modjo/39a50e93-4c35-4598-a6b8-9627986411e5/yocto/fsl-community-bsp/sources/poky/bitbake/lib/bb/parse/__init__.py", line 99, in handle return h['handle'](fn, data, include) File "/media/modjo/39a50e93-4c35-4598-a6b8-9627986411e5/yocto/fsl-community-bsp/sources/poky/bitbake/lib/bb/parse/parse_py/ConfHandler.py", line 147, in handle feeder(lineno, s, fn, statements) File "/media/modjo/39a50e93-4c35-4598-a6b8-9627986411e5/yocto/fsl-community-bsp/sources/poky/bitbake/lib/bb/parse/parse_py/ConfHandler.py", line 184, in feeder raise ParseError("unparsed line: '%s'" % s, fn, lineno); ParseError: ParseError at /media/modjo/39a50e93-4c35-4598-a6b8-9627986411e5/yocto/fsl-community-bsp/build/conf/bblayers.conf:18: unparsed line: 'BBLAYERS = " ${BSPDIR}/sources/poky/meta ${BSPDIR}/sources/poky/meta-yocto ${BSPDIR}/sources/meta-openembedded/meta-oe ${BSPDIR}/sources/meta-fsl-arm ${BSPDIR}/sources/meta-fsl-arm-extra ${BSPDIR}/sources/meta-ronga-udoo ${BSPDIR}/sources/meta-fsl-demos ${BSPDIR}/sources/meta-qt5 ' ERROR: Unable to parse /media/modjo/39a50e93-4c35-4598-a6b8-9627986411e5/yocto/fsl-community-bsp/build/conf/bblayers.conf: ParseError at /media/modjo/39a50e93-4c35-4598-a6b8-9627986411e5/yocto/fsl-community-bsp/build/conf/bblayers.conf:18: unparsed line: 'BBLAYERS = " ${BSPDIR}/sources/poky/meta ${BSPDIR}/sources/poky/meta-yocto ${BSPDIR}/sources/meta-openembedded/meta-oe ${BSPDIR}/sources/meta-fsl-arm ${BSPDIR}/sources/meta-fsl-arm-extra ${BSPDIR}/sources/meta-ronga-udoo ${BSPDIR}/sources/meta-fsl-demos ${BSPDIR}/sources/meta-qt5 ' Do you have an idea to resolve this ?
Hi Isronga, At first thanks for your reply ! I followed this tutorial but i obtained the same error : Code: ERROR: Traceback (most recent call last): File "/media/modjo/39a50e93-4c35-4598-a6b8-9627986411e5/yocto/fsl-community-bsp/sources/poky/bitbake/lib/bb/cookerdata.py", line 162, in wrapped return func(fn, *args) File "/media/modjo/39a50e93-4c35-4598-a6b8-9627986411e5/yocto/fsl-community-bsp/sources/poky/bitbake/lib/bb/cookerdata.py", line 172, in parse_config_file return bb.parse.handle(fn, data, include) File "/media/modjo/39a50e93-4c35-4598-a6b8-9627986411e5/yocto/fsl-community-bsp/sources/poky/bitbake/lib/bb/parse/__init__.py", line 99, in handle return h['handle'](fn, data, include) File "/media/modjo/39a50e93-4c35-4598-a6b8-9627986411e5/yocto/fsl-community-bsp/sources/poky/bitbake/lib/bb/parse/parse_py/ConfHandler.py", line 147, in handle feeder(lineno, s, fn, statements) File "/media/modjo/39a50e93-4c35-4598-a6b8-9627986411e5/yocto/fsl-community-bsp/sources/poky/bitbake/lib/bb/parse/parse_py/ConfHandler.py", line 184, in feeder raise ParseError("unparsed line: '%s'" % s, fn, lineno); ParseError: ParseError at /media/modjo/39a50e93-4c35-4598-a6b8-9627986411e5/yocto/fsl-community-bsp/build/conf/bblayers.conf:21: unparsed line: 'BBLAYERS = " ${BSPDIR}/sources/poky/meta ${BSPDIR}/sources/poky/meta-yocto ${BSPDIR}/sources/meta-openembedded/meta-ruby ${BSPDIR}/sources/meta-openembedded/meta-multimedia ${BSPDIR}/sources/meta-fsl-arm ${BSPDIR}/sources/meta-fsl-arm-extra #${BSPDIR}/sources/meta-ronga-udoo ${BSPDIR}/sources/meta-fsl-demos ${BSPDIR}/sources/meta-qt5 ' ERROR: Unable to parse /media/modjo/39a50e93-4c35-4598-a6b8-9627986411e5/yocto/fsl-community-bsp/build/conf/bblayers.conf: ParseError at /media/modjo/39a50e93-4c35-4598-a6b8-9627986411e5/yocto/fsl-community-bsp/build/conf/bblayers.conf:21: unparsed line: 'BBLAYERS = " ${BSPDIR}/sources/poky/meta ${BSPDIR}/sources/poky/meta-yocto ${BSPDIR}/sources/meta-openembedded/meta-ruby ${BSPDIR}/sources/meta-openembedded/meta-multimedia ${BSPDIR}/sources/meta-fsl-arm ${BSPDIR}/sources/meta-fsl-arm-extra #${BSPDIR}/sources/meta-ronga-udoo ${BSPDIR}/sources/meta-fsl-demos ${BSPDIR}/sources/meta-qt5 ' for information, my bblayers.conf : Code: LCONF_VERSION = "6" BBPATH = "${TOPDIR}" BSPDIR := "${@os.path.abspath(os.path.dirname(d.getVar('FILE', True)) + '/../..')}" #BSPDIR := "${/media/modjo/39a50e93-4c35-4598-a6b8-9627986411e5/#yocto/fsl-community-bsp/} BBFILES ?= "" BBLAYERS = " \ ${BSPDIR}/sources/poky/meta \ ${BSPDIR}/sources/poky/meta-yocto \ \ ${BSPDIR}/sources/meta-openembedded/meta-ruby \ ${BSPDIR}/sources/meta-openembedded/meta-multimedia \ \ ${BSPDIR}/sources/meta-fsl-arm \ ${BSPDIR}/sources/meta-fsl-arm-extra \ #${BSPDIR}/sources/meta-ronga-udoo \ ${BSPDIR}/sources/meta-fsl-demos \ ${BSPDIR}/sources/meta-qt5 \ " and my local.conf : Code: MACHINE ??= 'udoo-quad' DISTRO ?= 'poky' PACKAGE_CLASSES ?= "package_rpm" EXTRA_IMAGE_FEATURES = "debug-tweaks" USER_CLASSES ?= "buildstats image-mklibs image-prelink" PATCHRESOLVE = "noop" BB_DISKMON_DIRS = "\ STOPTASKS,${TMPDIR},1G,100K \ STOPTASKS,${DL_DIR},1G,100K \ STOPTASKS,${SSTATE_DIR},1G,100K \ ABORT,${TMPDIR},100M,1K \ ABORT,${DL_DIR},100M,1K \ ABORT,${SSTATE_DIR},100M,1K" CONF_VERSION = "1" BB_NUMBER_THREADS = '2' PARALLEL_MAKE = '-j 4' DL_DIR ?= "${BSPDIR}/downloads/" ACCEPT_FSL_EULA = "" EXTRA_IMAGE_FEATURES = "debug-tweaks ssh-server-openssh " IMAGE_INSTALL_append = " gcc g++ binutils libgcc libgcc-dev libstdc++ libstdc++-dev libstdc++-staticdev \ autoconf automake ccache chkconfig glib-networking glibmm \ packagegroup-core-buildessential pkgconfig \ boost cmake zlib glib-2.0 packagegroup-fsl-tools-testapps \ ruby \ cpufrequtils \ nano \ gdb \ gstreamer \ gst-meta-video \ gst-fsl-plugin \ gst-plugins-base-app \ gst-plugins-base \ gst-plugins-good \ gst-plugins-good-rtsp \ gst-plugins-good-udp \ gst-plugins-good-rtpmanager \ gst-plugins-good-rtp \ gst-plugins-good-video4linux2 \ openssh-sftp-server \ packagegroup-fsl-gstreamer \ packagegroup-fsl-tools-testapps \ packagegroup-fsl-tools-benchmark \ imx-vpu \ imx-test \ qtbase-fonts \ qtbase-plugins \ qtbase-tools \ qtbase-examples \ qtdeclarative \ qtdeclarative-plugins \ qtdeclarative-tools \ qtdeclarative-examples \ qtdeclarative-qmlplugins \ qtmultimedia \ qtmultimedia-plugins \ qtmultimedia-examples \ qtmultimedia-qmlplugins \ qtsvg \ qtsvg-plugins \ qtsensors \ qtimageformats-plugins \ qtsystems \ qtsystems-tools \ qtsystems-examples \ qtsystems-qmlplugins \ qtscript \ qt3d \ qt3d-examples \ qt3d-qmlplugins \ qt3d-tools \ qtwebkit \ qtwebkit-examples-examples \ qtwebkit-qmlplugins \ qtgraphicaleffects-qmlplugins \ qtconnectivity-qmlplugins \ qtlocation-plugins \ qtlocation-qmlplugins \ cinematicexperience \ cairo pango fontconfig freetype pulseaudio dbus \ alsa-lib alsa-tools alsa-state alsa-utils-alsaconf fsl-alsa-plugins \ i2c-tools \ " I don't know where is the problem ? Perhaps there is a bug under ubuntu 14.04 LTS ! I tried with dora branch and master branch and same problem (i take the same branch for qt5). :|
Hi all, I'm trying to build the ronga-image-qt5 but I received the following message after running "bitbake ronga-image-qt5": ERROR: Required build target 'ronga-image-qt5' has no buildable providers. Missing or unbuildable dependency chain was: ['ronga-image-qt5', 'qtbase'] How can I solve it ? Thanks, Riccardo
