no sound in Android
Discussion in 'Android' started by changks, Oct 25, 2013.
  1. changks
    changks New Member
    Oct 25, 2013
    Dear all,
    How to active analog sound?
    I plug my speaker line in, but it seems need further settings.
    Any tips?
    Thanks,
    Michael
  2. andcmp
    andcmp New Member
    161
    At the moment audio under Android works only over HDMI, we know this narrow down the possibilities and we are working on it.
  3. changks
    changks New Member
    Oct 25, 2013
    Can I get the sound out under Ubuntu OS?
  4. Suppaman
    Suppaman New Member
    Oct 29, 2013
    25
    To be more precise Android automatically connect to the first audio device found. HDMI audio is detected as first sound device and the audio onboard is the second. This is the reasons until HDMI will be connected the HDMI audio will be always used. Android, by default, doesn't have a settings to switch between multiple audio devices. I suppose it will be need to "invent" something for fix this issue...
  5. killkrt
    killkrt New Member
    Nov 1, 2013
    22
    It is not possible right now to change this setting using some app (likely in root mode)?
    Thank you.
  6. Suppaman
    Suppaman New Member
    Oct 29, 2013
    25
    Well, as already said, the problem is Android doesn't natively allow to manage multiple sound devices than I don't know if it will be possible to switch on run time between the two devices using code. Maybe an hard workaround inside the framework could be reach such result bot someone have to "invent" it right now...
  7. jehamann
    jehamann New Member
    Dec 13, 2013
    so what happens when you have no sound through hdmi???
