Hello, I've been experiencing issues booting the new UDOOBuntu OS for a Quad board. When I plug it in it immediately flashes a system info screen that displays the UDOO logo and basic system info like " CPU: Freescale i.MX6Q rev1.2 at 792 MHz". After about 3 seconds it reverts to a black screen and remains black no matter how long I wait. The debug output doesn't seem to match anything on the http://www.udoo.org/faq-items/why-my-udoo-wont-boot/ page. The culprit seems to be the line- which seems to imply a data corruption. I repeatedly checked the hash to confirm the files integrity though I should mention that downloads from sourceforge and the direct link were flagged as corrupt on two different MAC machines and two different Linux for which one download even caused a kernel panic! Code: CPU: Freescale i.MX6Q rev1.2 at 792 MHz Reset cause: POR Board: UDOO DRAM: 1 GiB MMC: FSL_SDHC: 0 No panel detected: default to LDB-WVGA Display: LDB-WVGA (800x480) In: serial Out: serial Err: serial Net: using phy at 6 FEC [PRIME] Hit any key to stop autoboot: 0 AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode flags: ncq stag pm led clo only pmp pio slum part No port device detected! sata - SATA sub system Usage: sata init - init SATA sub system sata info - show available SATA devices sata device [dev] - show or set current device sata part [dev] - print partition table sata read addr blk# cnt sata write addr blk# cnt AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode flags: ncq stag pm led clo only pmp pio slum part No port device detected! sata - SATA sub system Usage: sata init - init SATA sub system sata info - show available SATA devices sata device [dev] - show or set current device sata part [dev] - print partition table sata read addr blk# cnt sata write addr blk# cnt Booting from mmc ... 4788388 bytes read in 364 ms (12.5 MiB/s) ## Booting kernel from Legacy Image at 12000000 ... Image Name: Linux-3.0.35 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 4788324 Bytes = 4.6 MiB Load Address: 10008000 Entry Point: 10008000 Verifying Checksum ... OK Loading Kernel Image ... OK Starting kernel ... [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Linux version 3.0.35 (udoo@ubuntu) (gcc version 4.4.4 (4.4.4_09.0 6.2010) ) #7 SMP PREEMPT Thu Jul 3 15:12:59 CEST 2014 [ 0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d [ 0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: SECO i.Mx6 UDOO Board [ 0.000000] Kernel ver: v. 131\nMemory policy: ECC disabled, Data cache write alloc [ 0.000000] CPU identified as i.MX6Q, silicon rev 1.2 [ 0.000000] PERCPU: Embedded 7 pages/cpu @8c008000 s5504 r8192 d14976 u32768 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pag es: 227328 [ 0.000000] Kernel command line: console=ttymxc1,115200 root=/dev/mmcblk0p1 r ootwait rw fbmem=24M gpu_reserved=128M video=mxcfb0:dev=hdmi,1920x1080M@60,bpp=3 2 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Memory: 640MB 256MB = 896MB total [ 0.000000] Memory: 895020k/895020k available, 153556k reserved, 0K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] DMA : 0xf4600000 - 0xffe00000 ( 184 MB) [ 0.000000] vmalloc : 0xc0800000 - 0xf2000000 ( 792 MB) [ 0.000000] lowmem : 0x80000000 - 0xc0000000 (1024 MB) [ 0.000000] pkmap : 0x7fe00000 - 0x80000000 ( 2 MB) [ 0.000000] modules : 0x7f000000 - 0x7fe00000 ( 14 MB) [ 0.000000] .init : 0x80008000 - 0x8003a000 ( 200 kB) [ 0.000000] .text : 0x8003a000 - 0x80c474f0 (12342 kB) [ 0.000000] .data : 0x80c48000 - 0x80cb4c80 ( 436 kB) [ 0.000000] .bss : 0x80cb4ca4 - 0x80d077e4 ( 331 kB) [ 0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=4, N odes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] NR_IRQS:624 [ 0.000000] MXC GPIO hardware [ 0.000000] sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 14 31655ms [ 0.000000] arm_max_freq=1GHz [ 0.000000] MXC_Early serial console at MMIO 0x21e8000 (options '115200') [ 0.000000] bootconsole [ttymxc1] enabled [ 0.000000] Console: colour dummy device 80x30 [ 0.219502] Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280) [ 0.307839] pid_max: default: 32768 minimum: 301 [ 0.312724] Mount-cache hash table entries: 512 [ 0.317970] Initializing cgroup subsys cpuacct [ 0.322471] Initializing cgroup subsys devices [ 0.326930] Initializing cgroup subsys freezer [ 0.331421] Initializing cgroup subsys blkio [ 0.335759] CPU: Testing write buffer coherency: ok [ 0.340915] hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counter s available [ 0.441445] CPU1: Booted secondary processor [ 0.521446] CPU2: Booted secondary processor [ 0.601467] CPU3: Booted secondary processor [ 0.640951] Brought up 4 CPUs [ 0.656778] SMP: Total of 4 processors activated (6324.22 BogoMIPS). [ 0.663578] devtmpfs: initialized [ 0.683844] print_constraints: dummy: [ 0.687837] NET: Registered protocol family 16 [ 0.696721] print_constraints: vddpu: 725 <--> 1300 mV at 1150 mV fast normal [ 0.704303] print_constraints: vddcore: 725 <--> 1300 mV at 1150 mV fast norm al [ 0.712076] print_constraints: vddsoc: 725 <--> 1300 mV at 1200 mV fast norma l [ 0.719716] print_constraints: vdd2p5: 2000 <--> 2775 mV at 2400 mV fast norm al [ 0.727490] print_constraints: vdd1p1: 800 <--> 1400 mV at 1100 mV fast norma l [ 0.735173] print_constraints: vdd3p0: 2625 <--> 3400 mV at 3000 mV fast norm al [ 0.744264] [ 0.744270] > UDOO quad [ 0.748043] > rev C Called set_gpios_direction [ 0.752721] Test and set gpios directions and values by Gionji feat. Ekirei t est [ 0.784532] Resetting ethernet physical layer. [ 0.827768] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers. [ 0.834604] hw-breakpoint: 1 breakpoint(s) reserved for watchpoint single-ste p. [ 0.841964] hw-breakpoint: maximum watchpoint size is 4 bytes. [ 0.847851] L310 cache controller enabled [ 0.851894] l2x0: 16 ways, CACHE_ID 0x410000c7, AUX_CTRL 0x02070000, Cache si ze: 1048576 B [ 0.902376] bio: create slab <bio-0> at 0 [ 0.909837] mxs-dma mxs-dma-apbh: initialized [ 0.914559] print_constraints: vmmc: 3300 mV [ 0.919675] vgaarb: loaded [ 0.923247] SCSI subsystem initialized [ 0.928142] usbcore: registered new interface driver usbfs [ 0.933801] usbcore: registered new interface driver hub [ 0.939306] usbcore: registered new device driver usb [ 0.944387] Freescale USB OTG Driver loaded, $Revision: 1.55 $ [ 0.970950] imx-ipuv3 imx-ipuv3.0: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F( 6,7) [ 0.990944] imx-ipuv3 imx-ipuv3.1: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F( 6,7) [ 0.998774] mxc_mipi_csi2 mxc_mipi_csi2: i.MX MIPI CSI2 driver probed [ 1.005256] mxc_mipi_csi2 mxc_mipi_csi2: i.MX MIPI CSI2 dphy version is 0x313 0302a [ 1.012980] MIPI CSI2 driver module loaded [ 1.017345] Advanced Linux Sound Architecture Driver Version 1.0.24. [ 1.024559] Bluetooth: Core ver 2.16 [ 1.028271] NET: Registered protocol family 31 [ 1.032740] Bluetooth: HCI device and connection manager initialized [ 1.039116] Bluetooth: HCI socket layer initialized [ 1.044018] Bluetooth: L2CAP socket layer initialized [ 1.049149] Bluetooth: SCO socket layer initialized [ 1.054508] cfg80211: Calling CRDA to update world regulatory domain [ 1.061948] i2c-core: driver [max17135] using legacy suspend method [ 1.068236] i2c-core: driver [max17135] using legacy resume method [ 1.074464] Switching to clocksource mxc_timer1 [ 1.094521] NET: Registered protocol family 2 [ 1.099107] IP route cache hash table entries: 32768 (order: 5, 131072 bytes) [ 1.107019] TCP established hash table entries: 131072 (order: 8, 1048576 byt es) [ 1.116357] TCP bind hash table entries: 65536 (order: 7, 786432 bytes) [ 1.124094] TCP: Hash tables configured (established 131072 bind 65536) [ 1.130743] TCP reno registered [ 1.133903] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 1.139885] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 1.146616] NET: Registered protocol family 1 [ 1.151294] RPC: Registered named UNIX socket transport module. [ 1.157234] RPC: Registered udp transport module. [ 1.161971] RPC: Registered tcp transport module. [ 1.166690] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 1.174067] PMU: registered new PMU device of type 0 [ 1.179204] Static Power Management for Freescale i.MX6 [ 1.184447] wait mode is enabled for i.MX6 [ 1.188754] cpaddr = c0880000 suspend_iram_base=c08fc000 [ 1.194182] PM driver module loaded [ 1.198089] IMX usb wakeup probe [ 1.201807] add wake up source irq 75 [ 1.209093] IMX usb wakeup probe [ 1.212619] cpu regulator mode:ldo_enable [ 1.216839] i.MXC CPU frequency driver [ 1.243240] VFS: Disk quotas dquot_6.5.2 [ 1.247505] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 1.258016] JFFS2 version 2.2. (NAND) �© 2001-2006 Red Hat, Inc. [ 1.264868] fuse init (API version 7.16) [ 1.269684] msgmni has been set to 1748 [ 1.275099] alg: No test for stdrng (krng) [ 1.279381] io scheduler noop registered [ 1.283318] io scheduler deadline registered [ 1.287696] io scheduler cfq registered (default) [ 1.293494] MIPI DSI driver module loaded [ 1.297687] mxc_sdc_fb mxc_sdc_fb.0: register mxc display driver hdmi [ 1.304203] mxc_hdmi mxc_hdmi: Detected HDMI controller 0x13:0xa:0xa0:0xc1 [ 1.311126] fbcvt: 1920x1080@60: CVT Name - 2.073M9 [ 1.316028] fb_videomode = 59 1920 1080 5780 328 128 3 32 200 5 2 0 32 [ 1.334770] imx-ipuv3 imx-ipuv3.0: WARNING: adapt panel end blank lines [ 1.349117] imx-ipuv3 imx-ipuv3.0: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~ 5), 5F(6,7) [ 1.382428] imx-ipuv3 imx-ipuv3.0: WARNING: adapt panel end blank lines [ 1.415808] Console: switching to colour frame buffer device 160x64 [ 1.463915] mxc_sdc_fb mxc_sdc_fb.1: register mxc display driver ldb [ 1.470331] _regulator_get: get() with no identifier [ 1.482050] mxc_sdc_fb mxc_sdc_fb.2: register mxc display driver ldb [ 1.493247] imx-sdma imx-sdma: loaded firmware 1.1 [ 1.502341] imx-sdma imx-sdma: initialized [ 1.639468] Serial: IMX driver [ 1.642643] imx-uart.0: ttymxc0 at MMIO 0x2020000 (irq = 58) is a IMX [ 1.649516] imx-uart.1: ttymxc1 at MMIO 0x21e8000 (irq = 59) is a IMX [ 1.655995] console [ttymxc1] enabled, bootconsole disabled [ 1.655995] console [ttymxc1] enabled, bootconsole disabled [ 1.667521] imx-uart.3: ttymxc3 at MMIO 0x21f0000 (irq = 61) is a IMX [ 1.679685] loop: module loaded [ 1.683222] request BOSSA_CLK IRQ [ 1.686540] registering IRQ 419 for BOSSAC Arduino erase/reset operation [ 1.736366] No sata disk. [ 1.740340] GPMI NAND driver registered. (IMX) [ 1.745785] vcan: Virtual CAN interface driver [ 1.750252] CAN device driver interface [ 1.754090] flexcan netdevice driver [ 1.757827] FEC Ethernet Driver [ 1.763228] fec_enet_mii_bus: probed [ 1.770062] usbcore: registered new interface driver rt2800usb [ 1.775899] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.782562] fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller [ 1.789217] fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1 [ 1.819074] fsl-ehci fsl-ehci.0: irq 75, io base 0x02184000 [ 1.839064] fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00 [ 1.845319] hub 1-0:1.0: USB hub found [ 1.849098] hub 1-0:1.0: 1 port detected [ 1.853191] add wake up source irq 72 [ 1.856891] fsl-ehci fsl-ehci.1: Freescale On-Chip EHCI Host Controller [ 1.863536] fsl-ehci fsl-ehci.1: new USB bus registered, assigned bus number 2 [ 1.909060] fsl-ehci fsl-ehci.1: irq 72, io base 0x02184200 [ 1.939052] fsl-ehci fsl-ehci.1: USB 2.0 started, EHCI 1.00 [ 1.945247] hub 2-0:1.0: USB hub found [ 1.949011] hub 2-0:1.0: 1 port detected [ 1.953445] usbcore: registered new interface driver usbtmc [ 1.959023] Initializing USB Mass Storage driver... [ 1.964170] usbcore: registered new interface driver usb-storage [ 1.970193] USB Mass Storage support registered. [ 1.975061] usbcore: registered new interface driver usbserial [ 1.981020] USB Serial support registered for generic [ 1.986187] usbcore: registered new interface driver usbserial_generic [ 1.992731] usbserial: USB Serial Driver core [ 1.997200] USB Serial support registered for debug [ 2.002213] usbcore: registered new interface driver debug [ 2.007706] ARC USBOTG Device Controller driver (1 August 2005) [ 2.013998] g_ether gadget: using random self ethernet address [ 2.019859] g_ether gadget: using random host ethernet address [ 2.026435] usb0: MAC 7a:a2:2d:bb:f0:45 [ 2.030291] usb0: HOST MAC 2e:85:14:6d:87:17 [ 2.034566] g_ether gadget: controller 'fsl-usb2-udc' not recognized; trying CDC Ethernet (ECM) [ 2.043302] g_ether gadget: Ethernet Gadget, version: Memorial Day 2008 [ 2.049937] g_ether gadget: g_ether ready [ 2.053948] Suspend udc for OTG auto detect [ 2.079080] fsl-usb2-udc: bind to driver g_ether [ 2.084332] mousedev: PS/2 mouse device common for all mice [ 2.090480] usbcore: registered new interface driver usbtouchscreen [ 2.097155] Sitronix touch driver 2.9.1 [ 2.101009] Release date: 20120507 [ 2.104788] sitronix_reset_ic [ 2.228013] send status reg command error (-5) [ 2.232484] sitronix: probe of 2-0055 failed with error -5 [ 2.238954] snvs_rtc snvs_rtc.0: rtc core: registered snvs_rtc as rtc0 [ 2.245645] i2c /dev entries driver [ 2.249923] Linux media interface: v0.10 [ 2.253954] Linux video capture interface: v2.00 [ 2.289068] usb 2-1: new high speed USB device number 2 using fsl-ehci [ 2.389643] camera ov5640_mipi is found [ 2.393895] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as vide o16 [ 2.401533] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as vide o17 [ 2.409222] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as vide o18 [ 2.416891] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as vide o19 [ 2.424528] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as vide o20 [ 2.432330] vivi-000: V4L2 device registered as video2 [ 2.437474] Video Technology Magazine Virtual Video Capture Board ver 0.8.0 s uccessfully loaded. [ 2.446786] usbcore: registered new interface driver uvcvideo [ 2.452591] USB Video Class driver (v1.1.0) [ 2.457580] hub 2-1:1.0: USB hub found [ 2.461502] i2c-core: driver [mag3110] using legacy suspend method [ 2.461525] hub 2-1:1.0: 4 ports detected [ 2.471713] i2c-core: driver [mag3110] using legacy resume method [ 2.478284] imx2-wdt imx2-wdt.0: IMX2+ Watchdog Timer enabled. timeout=60s (n owayout=1) [ 2.486407] Bluetooth: Virtual HCI driver ver 1.3 [ 2.491344] Bluetooth: HCI UART driver ver 2.2 [ 2.495792] Bluetooth: HCI H4 protocol initialized [ 2.500605] Bluetooth: HCI BCSP protocol initialized [ 2.505571] Bluetooth: HCILL protocol initialized [ 2.510283] Bluetooth: HCIATH3K protocol initialized [ 2.515248] Bluetooth: Generic Bluetooth USB driver ver 0.6 [ 2.520957] usbcore: registered new interface driver btusb [ 2.526588] sdhci: Secure Digital Host Controller Interface driver [ 2.532783] sdhci: Copyright(c) Pierre Ossman [ 2.537459] mmc0: SDHCI controller on platform [sdhci-esdhc-imx.2] using DMA [ 2.544788] mxc_vdoa mxc_vdoa: i.MX Video Data Order Adapter(VDOA) driver pro bed [ 2.552845] VPU initialized [ 2.556168] mxc_asrc registered [ 2.576785] Thermal calibration data is 0x5744e569 [ 2.581599] Thermal sensor with ratio = 180 [ 2.600419] Anatop Thermal registered as thermal_zone0 [ 2.605718] anatop_thermal_probe: default cooling device is cpufreq! [ 2.613066] usbcore: registered new interface driver usbhid [ 2.618643] usbhid: USB HID core driver [ 2.622971] usbcore: registered new interface driver snd-usb-audio [ 2.629715] mxc_hdmi_soc mxc_hdmi_soc.0: MXC HDMI Audio [ 2.635188] Cirrus Logic CS42888 ALSA SoC Codec Driver [ 2.640450] i2c-core: driver [cs42888] using legacy suspend method [ 2.646633] i2c-core: driver [cs42888] using legacy resume method [ 2.652860] mmc0: new high speed SDHC card at address 1234 [ 2.658734] mmcblk0: mmc0:1234 SA08G 7.28 GiB [ 2.665048] mmcblk0: p1 [ 2.735511] audio_codec_ac97_cold_reset [ 2.769195] usb 2-1.3: new high speed USB device number 3 using fsl-ehci [ 2.821632] Found Audio codec AC97 vt1613, [ID = 5649 - 4123] [ 2.839828] asoc: vt1613 <-> imx-ssi.0 mapping ok [ 2.846240] imx_3stack asoc driver [ 2.851227] asoc: mxc-hdmi-soc <-> imx-hdmi-soc-dai.0 mapping ok [ 2.857922] ALSA device list: [ 2.860905] #0: vt1613-audio [ 2.863960] #1: imx-hdmi-soc [ 2.867220] NET: Registered protocol family 26 [ 2.872263] TCP cubic registered [ 2.875494] NET: Registered protocol family 17 [ 2.879964] can: controller area network core (rev 20090105 abi 8) [ 2.886216] NET: Registered protocol family 29 [ 2.890703] can: raw protocol (rev 20090105) [ 2.894977] can: broadcast manager protocol (rev 20090105 t) [ 2.900730] Bluetooth: RFCOMM TTY layer initialized [ 2.905616] Bluetooth: RFCOMM socket layer initialized [ 2.910765] Bluetooth: RFCOMM ver 1.11 [ 2.914517] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 2.919837] Bluetooth: BNEP filters: protocol multicast [ 2.925064] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 2.931153] lib80211: common routines for IEEE802.11 drivers [ 2.936845] Registering the dns_resolver key type [ 2.941592] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4 [ 2.949711] Bus freq driver module loaded [ 2.953727] Bus freq driver Enabled [ 2.959052] mxc_dvfs_core_probe [ 2.962393] DVFS driver module loaded [ 2.967674] snvs_rtc snvs_rtc.0: setting system clock to 1970-01-01 00:00:00 UTC (0) [ 2.981625] EXT3-fs: barriers not enabled [ 5.618114] kjournald starting. Commit interval 5 seconds [ 5.618188] EXT3-fs (mmcblk0p1): warning: mounting fs with errors, running e2 fsck is recommended [ 5.634440] EXT3-fs (mmcblk0p1): using internal journal [ 5.639682] EXT3-fs (mmcblk0p1): recovery complete [ 5.648066] EXT3-fs (mmcblk0p1): mounted filesystem with writeback data mode [ 5.655156] VFS: Mounted root (ext3 filesystem) on device 179:1. [ 5.665434] devtmpfs: mounted [ 5.668459] Freeing init memory: 200K [ 6.307123] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe renced: 385025 [ 6.318626] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe renced: 385025 [ 6.330040] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe renced: 385025 [ 6.341424] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe renced: 385025 [ 6.390545] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe renced: 376833 [ 6.402289] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe renced: 376833 [ 6.416798] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe renced: 376833 [ 6.428477] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe renced: 376833 [ 6.442065] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe renced: 385025 [ 6.454665] init: mountall main process (1633) terminated with status 1 [ 6.476818] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe renced: 385025 [ 6.488887] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe renced: 385025 [ 6.500272] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe renced: 385025 [ 6.511635] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe renced: 385025 General error mounting filesystems. A maintenance shell will now be started. CONTROL-D will terminate this shell and reboot the system. [ 6.634313] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe renced: 376833 [ 6.646058] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe renced: 376833 Give root password for maintenance (or type Control-D to continue): [ 12.216123] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe renced: 376833 [ 12.238257] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe renced: 376833 [ 12.251243] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe renced: 385025 [ 12.262703] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe renced: 385025 [ 12.274085] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe renced: 385025 [ 12.285467] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe renced: 385025 [ 12.304884] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe renced: 385025 [ 12.316584] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe renced: 385025 [ 12.328165] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe renced: 385025 [ 12.339612] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe renced: 385025 bash: groups: command not found[ 12.354096] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode referenced: 385025 [ 12.366213] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe renced: 385025
Okay, I tried all over again. Using a new SD Card, downloading the torrent, unpacking in Linux and flashing via DD Command. This time I seemed to get a little further but still short of boot. Connected via HDMI it shows an actual boot sequence dialog, as opposed to last time where it was just a black screen. Unfortunately it seems to hang after failing to open a vncserver. Serial Debug output is similar to last time in that it still shows the warning, but I was able to get into a login and what appeared to be a root shell. Unfortunately, it won't accept any commands returning the following after inputting startx- Code: u@udoobuntu: ~ $ 0;[ubuntu@udoobuntu] ~startx [ 68.410757] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe renced: 409601 mktemp: failed to create file via template `/tmp/serverauth.XXXXXXXXXX': Input/o utput error /usr/bin/startx: 155: /usr/bin/startx: xauth: not found /usr/bin/startx: 172: /usr/bin/startx: xauth: not found /usr/bin/startx: 172: /usr/bin/startx: xauth: not found xinit: error while loading shared libraries: libxcb.so.1: cannot open shared obj ect file: No such file or directory /usr/bin/startx: 204: /usr/bin/startx: xauth: not found -bash: awk: command not found -bash: [: -gt: unary operator expected -bash: [: -gt: unary operator expected ubuntu@udoobuntu: ~ $ 0;[ubuntu@udoobuntu] ~[ 327.105917] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode referenced: 409601 [ 1024.144425] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe renced: 409601
