Pwm on SAM3x and control on iMx6
Discussion in 'Arduino IDE' started by msener, Dec 2, 2014.
  1. msener
    msener New Member
    Dec 1, 2014
    Hello,
    Can someone help me?
    I couldn't produce PWM signal at SAM3x.
    I want to enter pwm parametre and SAM3x produce PWM.
    And also at terminal I wrote:
    stty -F /dev/ttymxc3 cs8 115200 // to configuration
    echo message> /dev/ttymxc3 // to send message and i want to send pwm parametre
    cat /dev/ttymxc3 // to read message but i can't take any message
    Thanks.
  2. gionji
    gionji Member
    Jun 28, 2013
    38
    Hi
    you need to write a Arduino code that reads integer or simply a byte (values from 0 to 255) and then set this value with analogWrite function>
    void setup(){
    pinMode(9, OUTPUT);
    Serial.begin(115200);
    void loop(){
    int readedByte = 0;
    if(Serial.available()){
    readedByte = Serial.read();
    analogWrite(9, readedByte);
    delay(20);
  3. Karthikeyan Jaganathan
    Karthikeyan Jaganathan New Member
    May 23, 2015
    If I use the command analog write to produce the PWM waves, the maximum duty cycle achievable was around 1200 microseconds......... but for my application i need to produce a maximum of 2200 microsesconds....... Is there any other way to produce PWM signal ?
