new OpenELEC
Discussion in 'XBMC' started by vpeter, Dec 12, 2014.
  1. JoostK
    JoostK New Member
    Dec 15, 2014
    Thanks @vpeter. Any changes we should be aware of, or is this only the Kodi 14.0 release?
  2. vpeter
    vpeter Active Member
    Nov 29, 2014
    303
    62
    All changes are still the same as for official imx6 build.
  3. mmeinert
    mmeinert Member
    Jun 17, 2014
    61
  4. sebg
    sebg New Member
    Dec 29, 2014
    I've tested this build yesterday, and it passed my basic tests (720p / 1080p videos ripped from youtube, read from dlna and smb shares), sound and video ok
    next step is trying to scrape a medium-to-large collection (movies/tvshows/music), maybe at the end of the week
    thanks alot for your work !
  5. idorel77
    idorel77 Member
    Jul 25, 2014
    131
    Hello vpeter,
    thanks for your work.
    Can i have the source code and some intruction or can you add suport for usb eGalax touchscreen?
    Thank you.
  6. vpeter
    Nov 29, 2014
    303
    62
    Currently udoo is not yet supported (and others also not). When my changes for imx6 project will be merged I will also update for udoo.
  7. vpeter
    Nov 29, 2014
    303
    62
  8. idorel77
    idorel77 Member
    Jul 25, 2014
    131
    Hi vpeter, thanks a lot. I will.
  9. vpeter
    Nov 29, 2014
    303
    62
    If you have any question let me know. Here on PM.
  10. salouma
    salouma Member
    Jan 24, 2014
    49
    Vpeter what you have done is really really nice.
    It is the first stable kodi release I met.
    The system is very fast I love it !
    I looking a way to have Rsync in this distribution, have you a solution for that ?
    Thank you again !
  11. vpeter
    Nov 29, 2014
    303
    62
    Thank you very much.
    Install rsync addon from openelec unofficial repository.
  12. salouma
    salouma Member
    Jan 24, 2014
    49
    I did but the unnificial repository is empty.
    Did you find rsync in yours ?
  13. salouma
    salouma Member
    Jan 24, 2014
    49
    Sorry just needed a reboot!
  14. Qter
    Qter New Member
    vpeter. Excellent Job!!!
    Thank you.
  15. salouma
    salouma Member
    Jan 24, 2014
    49
    Hi Vpeter,
    Just a question, have you ever tried to boot on SATA with your OpenElec distribution.
    I write your image on a SATA hard disk but i 'm able to boot on it (of courses using a SD card looking for a boot in sda)
    best regards,
  16. vpeter
    Nov 29, 2014
    303
    62
    No. Doesn't have any spare disk.
    From what I see SATA is enabled in u-boot. I think you just need to set correct boot=/disk=. Same as you would use USB stick (on RPi - check openelec forum).
  17. salouma
    salouma Member
    Jan 24, 2014
    49
    Thank you very much, i replaced mmcbl0p1 with sda1 and mmcblk0p2 by sda2 and it worked like a charm on SATA boot.
    The problem now i'm meeting is the speed transfert with Rsync.
    That is something strange, i tried to Rsync with a remote server, on my X86 computer i have something la 8 to 10 MB/sec.
    With udoo i have only 700 kB/sec (or less).
    I tried the top command during transfert the CPU is not overloaded (only 7-9 % usage), more than 600 MB of ram is free
    If i do a local transfert inside my LAN using samba i reached 10 MB/sec which is my LAN maximum speed so it is not also a I/O hard disk speed problem.
    I can't get it why i got very slow transfert speed with Rsync. Any thought about that ?
    Best regards,
  18. vpeter
    Nov 29, 2014
    303
    62
    No though. I didn't done any network testing. Try to copy locally between hdd and usb stick for example.
  19. salouma
    salouma Member
    Jan 24, 2014
    49
    All local copy are OK.
    The problem is when i want to retrive data over the internet.
    I just used a wget command to try to download a file in a high speed server i also i can't go over 700 Kbits.
    If you have a high speed connection could you try a wget command to see if your are also limited in download speed ?
  20. vpeter
    Nov 29, 2014
    303
    62
    Testing locally between udoo and web server on Windows over 100 mbit network:
    OpenELEC:~/downnloads # dmesg | grep udoo
    [    1.071970] udoo_power_off_probe: pm_power_off function already registered, overwriting with ours
    [    1.072130] udoo_power_off_probe: ok
    OpenELEC:~/downnloads # curl -o test http://10.0.0.2:8000/test
      % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                     Dload  Upload   Total   Spent    Left  Speed
    100  103M  100  103M    0     0  9584k      0  0:00:11  0:00:11 --:--:-- 8670k
    Speed was almost 10MB/s. No problem on my board. Of course using cable - not with WiFi.
