Ubuntu Core Snappy on Udoo
Discussion in 'Other OS' started by freedomotic, Feb 9, 2015.
  1. freedomotic
    freedomotic Member
    Oct 19, 2013
    77
  2. vpeter
    vpeter Active Member
    Nov 29, 2014
    303
    62
    Just trying to make an image. It works on SolidRun's CuBox-i so should also on Udoo.
    I will post image and instructions soon (hoping today).
  3. freedomotic
    freedomotic Member
    Oct 19, 2013
    77
    Great!!
    I could collaborate as tester.
  4. vpeter
    Nov 29, 2014
    303
    62
    Download, extract and write image to SD card. It is for Udoo Quad. But someone can try on Dual.
    udoo-snappy.img.gz
    For first version it boots but I think something is wrong. I'm trying to install webdm but it doesn't start. Don't know why not. Need investigation.
    Also date is not set correctly (seems general problem). It must be set with command like
    sudo date -s "Feb 10 18:24:00 UTC 2015"
    Work is inspired by dz0ny who port Snappy to Cubox-i. Thank you.
    Build script is also available. I noticed that program ubuntu-device-flash created disk image with GPT partition table but then u-boot overwrites it. That's why I'm converting disk from GPT to MBR format when running flashtool-asset commands. For now it seems to work but not sure if this is long term solution.
  5. freedomotic
    freedomotic Member
    Oct 19, 2013
    77
    Great! Is it for dual or quad core? Or no difference?
  6. vpeter
    Nov 29, 2014
    303
    62
    Tested on Quad. But someone could try on Dual. Seems OpenELEC runs on both so this could also.
  7. freedomotic
    freedomotic Member
    Oct 19, 2013
    77
    I just started the image on Quad Core. It works!
    I set the date with your proposed command. It's ok. What problem did you find with it?
  8. vpeter
    Nov 29, 2014
    303
    62
    Try installing webdm for example. In my case it got installed but web server not started after reboot.
  9. freedomotic
    freedomotic Member
    Oct 19, 2013
    77
    Ok, I'll try. What about your date problem?
  10. vpeter
    Nov 29, 2014
    303
    62
    Seems this is problem with Snappy itself. At least what google found. Must add one package like ntp client and then system would be set with correct time. But for this I need to study little more how to achieve that.
  11. freedomotic
    freedomotic Member
    Oct 19, 2013
    77
    I made some tests.
    First of all if you doesn't set the date it's impossible to install any app.
    Infact server certificate verification failes, maybe because it can't check the expire date.
    After setting the date I installed webdm with
    sudo snappy install webdm
    Installation ok but impossible to access locally or remotely with http://192.168.0.234:4200 (192.168.0.234 is the default ip).
    I checked that avahi-daemon is not running.
    All ok with my cloud installation on Amazon EC2 .
  12. vpeter
    Nov 29, 2014
    303
    62
    Version2: everything works as expected. Setting date not needed, apps can be installed, ...
    Download, extract and write image to SD card: udoo-snappy.img.gz
    Now I have no idea what to do with it :p
  13. freedomotic
    freedomotic Member
    Oct 19, 2013
    77
    First of all the image could be added to the download section of Udoo.
  14. vpeter
    Nov 29, 2014
    303
    62
    How?
  15. freedomotic
    freedomotic Member
    Oct 19, 2013
    77
    I can ask Udoo's administrators.
    What changes have done from the first version to fix the problems?
  16. vpeter
    Nov 29, 2014
    303
    62
    Before I was using program ubuntu-device-flash from one deb archive which I though it's ok (I'm building on Ubuntu 12.04.5 LTS where is no ppa for this). But now I installed Ubuntu Vivid an copied this file from there. And all the problems went away (building ones and running too).
  17. humblehacker
    humblehacker New Member
    Apr 7, 2014
    16
    I only just learned about Ubuntu Core when I saw it available for the Raspberry Pi and it looks awesome! I also noticed Canonical has UDOO listed as an official partner on the Ubuntu Core webpage, but couldn't find anything on the Udoo download page. Is the link posted above the most recent version?
  18. vpeter
    Nov 29, 2014
    303
    62
    I think version made by me is the only one that exist.
    And I don't really see potential right now. Or doesn't even understand the purpose.
  19. freedomotic
    freedomotic Member
    Oct 19, 2013
    77
    Hi vpeter
    I'm working with your image to create a snap for our domotic framework.
    Would you like to collaborate for testing?
    Thanks
  20. vpeter
    Nov 29, 2014
    303
    62
    Thanks. But I just created this image to be useful for others.
    Let us inform about the progress anyway - maybe someone would use it.
