Hi to all, I need some help and I hope that this is the right place where to find it I have this display model : A070VW01 V1, it cames with a flat cable with 50 pins I think this is its datasheet: https://docs.google.com/file/d/0B-_wZv9 ... jNST09yNjA I have found on line some driving board but I can't find any that fit with mine lcd, could you help me? ps. i have found this: https://drive.google.com/file/d/0B-_wZv ... sp=sharing and this https://drive.google.com/file/d/0B-_wZv ... sp=sharing I have 2 ways to connect this panel to Udoo or via an hdmi control board that translate the signal from hdmi to this or via the lvds connection but i need the board that translate the signal from lvds standard to the panel... I don't know how to figure out the solution... could anyone help me? I don't know where to search... Thanks a lot
in the back of the official UDOO lvds 7" panel (a TFT-LCD too) there's a proprietary board that translates the panel's signal to LVDS to works with imx6. If you want you can contact me in pvt to give you more info about (datasheet or similar) and check if could be compatible.
