Will UDOO work from 5V 1A power supply?
Discussion in 'General Discussion' started by repu1sion, Jun 10, 2015.
  1. repu1sion
    repu1sion New Member
    Jun 10, 2015
    I have an UDOO-dual board without official power supply (12V 2A)
    but elinux.org/UDOO says it could work with 6V-15V range.
    Also one guy said that he tried 5V and it works just well.
    The question is - could I try to run UDOO with 5V 1A power supply (from Beaglebone Black) without risk to damage anything?
    Thanks for the help!
  2. Andrea Rovai
    Hi there repu1sion,
    that way the board won't get damaged, but it may not work properly due to the low voltage.
    CHeers!
  3. Andrea Rovai
    Hi there repu1sion,
    CHeers!
  4. repu1sion
    Jun 10, 2015
    Thanks. It really works until I start to connect lots of usb devices to it... ;)
    After that I have unexpected reboots probably because of not enough voltage.
    6V would be enough or I need exactly 12V to connect few USB devices to it and have it stable?
  5. Andrea Rovai
    12V to have it stable.
    Cheers!
  6. repu1sion
    Jun 10, 2015
    From my experience: it works fine on 5V 1A with hdmi display connected but until you start to connect USB devices. After that unexpected reboots follow.
  7. Andrea Rovai
    The solution is going for a proper PSU (12V 2A).
    Cheers
  8. Andrea Arezzini
    Andrea Arezzini New Member
    Jul 15, 2015
    what's the max current that udoo can support?
  9. Andrea Rovai
    Hi there,
    could you better specify your question? Are you talking about pins/power up,/what else?
  10. fetcher
    fetcher Member
    Mar 9, 2014
    166
    Any current level rating above the minimum is fine. The Udoo I'm routing through right now is connected to 100 amp-hours of batteries, part of a home solar power system :)
    It is important to include a fuse in your power lead, though, when connecting to a source capable of high current, to avoid the risk of fire or melted wires in the event of a short circuit caused by incorrect wiring or component failure. I use a 3A automotive fuse (ATC type) but any fuse in the range of 2A to 5A should be fine. Normally an Udoo will be pulling well under 1 amp.
    The Udoo does not come with a fuse already on-board because the small AC -> DC power supplies it would normally be used with contain their own overcurrent protection -- shorting out one of those should normally just shut it down without damage. This is not the case when running from a battery, though.
  11. Andrea Arezzini
    Jul 15, 2015
    ok thanks a lot for the advices
