Hello, Does M4 core is 5 volt tolerant on gpio pins? I want to connect a HC-SR04 ultrasonic distance sensor. It is 3.3 volt tolerant on trigger pin but i don't know if I can simply connect the output pin to the board without damaging the board itself. Thank you
Hi Flavio, This link will take you to a tutorial for using HC-SR04 on a Raspberry PI that also has 3.3v pins. http://www.modmypi.com/blog/hc-sr04-ultrasonic-range-sensor-on-the-raspberry-pi Regards John
Hello John, this is the same trick I used on banana pi. My disappointment is that an Arduino Uno shield could have 5 volt signals. I thought that there were logic-level translators on each M4 pin to accomplish that.
Dear Flavio, there's no logic-level translator as you say. In input you have to use a voltage divider. Take a look at this page.
