Installed Arduino IDE to program OTHER arduino boards
Discussion in 'UDOO NEO' started by mdoan7, Nov 4, 2015.
  1. mdoan7
    mdoan7 New Member
    Nov 4, 2015
    I know the installed arduino IDE 1.6.5r3 can program M4 but I need it to also program arduino Yun's on the network. I installed the boards but get a gcc error when I try to compile for Yuns.
    Is this something missing in the installed IDE?
  2. JackSilb
    JackSilb Active Member
    Nov 3, 2015
    100
    32
    Easy, just use the Arduino IDE to add more supported boards.
    From the Aurduino IDE -> Tools/Boards/Boards Manager
    Then add the board family that you want to program. This is the same way as on current Aruduino IDE releases for other OSes besides Linux. ex IDE 1.6.x
    You will probably be diaspointed with the sloooow speed on compiling Arduiono code using the current NEO build / Aurduino IDE.
    In my case I am not trying to use the Arduino IDE onNEO anymore. Too slow to wait for the compilation. I may try again on new releases.
    -Jack
  3. JackSilb
    Nov 3, 2015
    100
    32
  4. mdoan7
    mdoan7 New Member
    Nov 4, 2015
    You would have thought it to be so easy. However, when I did just that.. the IDE is not able to compile with gcc.
  5. JackSilb
    Nov 3, 2015
    100
    32
    It is never easy is it?! Sorry it is not working.
    I have not tried compiling to other boards yet. Not sure I would do it since the compilation, at least in my case, is sooooo sloow. I know this is all relative. But to program an Arduino today, I would not use and I am not using NEO.
    -Jack
  6. Andrea Rovai
    Dear mdoan7,
    what you mean by saying that your Neo doesn't compile with gcc? Could you be more specific?
  7. mdoan7
    mdoan7 New Member
    Nov 4, 2015
    This is what I get in the IDE console window when I try to compile a default (empty) program. Same thing for the blink or any sketch. I don't have any issues if the target is NEO.
    /home/mdoan/.arduino15/packages/arduino/tools/avr-gcc/4.8.1-arduino5/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10605 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8041 -DUSB_MANUFACTURER="Unknown" -DUSB_PRODUCT="Arduino Yun" -I/home/mdoan/.arduino15/packages/arduino/hardware/avr/1.6.5/cores/arduino -I/home/mdoan/.arduino15/packages/arduino/hardware/avr/1.6.5/variants/yun /tmp/build6054909777515112179.tmp/sketch_nov11a.cpp -o /tmp/build6054909777515112179.tmp/sketch_nov11a.cpp.o
    /home/mdoan/.arduino15/packages/arduino/tools/avr-gcc/4.8.1-arduino5/bin/avr-g++: 1: /home/mdoan/.arduino15/packages/arduino/tools/avr-gcc/4.8.1-arduino5/bin/avr-g++: Syntax error: "(" unexpected
    /home/mdoan/.arduino15/packages/arduino/tools/avr-gcc/4.8.1-arduino5/bin/avr-g++ returned 2
    Error compiling.
  8. Andrea Rovai
    So you are trying to compile for a different board from the Arduino IDE preinstalled on the NEO Linux distribution, aren't you?
    We haven't tried it yet. The Arduino IDE on UDOO Neo currently is a bit rusty, but in short time we'll use the standard method, the board manager I mean, so probably it'll get better
  9. mdoan7
    mdoan7 New Member
    Nov 4, 2015
    Yes, that was my intention. I have a unique case where I would like to take advantage of the NEO's arduino IDE to program other similarly networked Arduino's. I know others have reported that the IDE is painfully slow to compile, but that's not of concern in my use case. And yes, I understood that the Arduino side of NEO is not completely baked yet. Just wanted to present the question just incase someone else saw/solved it. Thanks for digging into it.
    Is it possible to install the "full" IDE from Arduino download? I downloaded the latest linux32 IDE but probably missed a step in the install.. the program does not run.. hmm... Although it won't program NEO without patching.. it might get me closer to my answer...
  10. Andrea Rovai
    Please, be clearer:
    • You are downloading the Arduino IDE from? The Arduino website or our website?
    • You are trying to program the Arduino IDE from? Cortex A9 or externally?
  11. mdoan7
    mdoan7 New Member
    Nov 4, 2015
    I downloaded from Arduino website.
    I want to use A9, running the Arduino IDE, to program a completely separate Arduino board (an Arduino Yun connected via ethernet on a common network to be specific).
  12. Andrea Rovai
    The Arduino that you downloaded from Arduino.cc is not compiled for an ARM architecture.
    It won't ever work, never ever, on the A9 of Neo. Unless you recompile it.
  13. Andrea Rovai
    Folk, I've been too much in a hurry.
    You should install the AVR package for the Arduino IDE preinstalled on the Neo.
    Launch the command:
    sudo apt-get install arduino-core-avr
