/var/opt/m4/m4last.fw permission problem
Discussion in 'UDOO NEO' started by nophead, Nov 5, 2015.
  1. nophead
    nophead UDOOer
    Aug 18, 2015
    87
    14
    When I try to download the blink sketch using the Arduino IDE on the desktop I get an error:
    cp: cannot create regular file 'var/opt/m4/m4last.fw' : Permission denied.
    This is because the file is owned by root and only has read permission for everybody else. Should I just delete it?
    Why am I seeing this problem? I did load the blink sketch via the web interface. Does that perhaps run as root?
    niv likes this.
  2. nophead
    nophead UDOOer
    Aug 18, 2015
    87
    14
    Yes deleting the file works. It gets recreated owned by udooer and then both the web interface demo and the IDE work. I think if you use the web demo first it will cause this bug.
    niv and Richard McCausland like this.
  3. nophead
    nophead UDOOer
    Aug 18, 2015
    87
    14
    BTW, why on earth does the blink sketch use 43K when it is running on an M4?
  4. mdoan7
    mdoan7 New Member
    Nov 4, 2015
    You'll find this problem every time you switch users and try to upload new firmware.
  5. niv
    niv New Member
    Nov 20, 2015
    Thank you!
