My QUAD running Ubuntu1204 V2.0 sees the wifi network, but it does not authenticate the password. I've tried both my primary and guest wifi connections without luck. I'm using the gui System Settings tool, not the command line. Wired connection works fine. Any suggestions to get wifi working would be appreciated.
Hello I'm using quad UDOO with Ubunto 12.04. When i try to setup the Wifi I have the same message asking the password for privileges. I try ubunto or the root password (set after a sudo -i) but it is refused. An idea Thank you.
yes the default password for the system us 'ubuntu' Were you stating you were typing it wrong and your are all set? Or that you are correcting your post and you are actually still having a problem?
Hi donhuntley What's the administrator password? Lubuntu software center asked me about password to install any package !!! Any suggestions please
