I want to install ubuntu-sdk, is it ok for udoo neo ?
Discussion in 'UDOO NEO' started by David wang, Jan 19, 2016.
  1. David wang
    David wang New Member
    Dec 1, 2015
    29
    Because I use the phone-wireless network as my udoo neo wifi connection in office, so I need to double confirm that whether the sdk is ok now for this platform! I donot want to waste my money! Thanks!
    The url
    https://developer.ubuntu.com/en/start/ubuntu-sdk/
    When I type in command line terminal, "sudo apt-get install ubuntu-sdk", there are some informations as follows
    [sudo] password for udooer:
    Reading package lists... Done
    Building dependency tree
    Reading state information... Done
      unity-settings-daemon unity-voice-service unity-webapps-qml unity8
      unity8-private upstart-app-launch upstart-app-launch-tools
      usermetricsservice wdiff whoopsie-preferences zeitgeist zeitgeist-core
      zeitgeist-datahub
    The following packages will be upgraded:
      libgstreamer-plugins-base1.0-0 libxml2
    2 upgraded, 432 newly installed, 0 to remove and 75 not upgraded.
    Need to get 226 MB/241 MB of archives.
    After this operation, 678 MB of additional disk space will be used.
    Do you want to continue? [Y/n] n
    Abort.
  2. David wang
    Dec 1, 2015
    29
    In other ways, can somebody tell me the difference between ubuntu os and udoo ubuntu os. Thanks in advance!
  3. klakier2121
    klakier2121 Member
    Dec 5, 2015
    48
    15
    QT Creator is not supported by UDOO Neo
  4. Andrea Rovai
    David wang likes this.
  5. David wang
    Dec 1, 2015
    29
    Ok, tomorrow, I will try to try it.
    If there are some good news, I wll tell you!
  6. klakier2121
    klakier2121 Member
    Dec 5, 2015
    48
    15
    Great news! QT is such a powerful tool
  7. David wang
    Dec 1, 2015
    29
  8. Andrea Rovai
    I didn't understand what you said, could you explain?
  9. David wang
    Dec 1, 2015
    29
    Please read the webpage which you supply firstly! Can you try it successfully step by steps?
  10. David wang
    Dec 1, 2015
    29
    Do not carry about this problem , I will follow this forum all the time!
  11. Xykon
    Xykon Member
    Nov 1, 2013
    64
    Is there an RSS feed for the blog? There is a link at the bottom of the page to http://www.udoo.org/feed.php but that gives a 404 error.
  12. Francesco
    Francesco Active Member
    Jun 23, 2015
    220
    110
  13. Francesco
    Jun 23, 2015
    220
    110
    Please note the "standard" Ubuntu OS is built for x86 or amd64. UDOO, being an ARM board, it uses the armhf port. This could be enough to break compatibility with ubuntu-sdk.
    The main differences between Ubuntu (armhf) and UDOObuntu are:
    - custom kernel
    - custom bootloader
    - libdrm, X, QT, chromium packages rebuilt to use the integrated GPU
    So, if ubuntu-sdk runs on a standard armhf Ubuntu, it will run also on UDOObuntu.
  14. delba
    Fixed it. Sorry for the broken link.
    Cheers
  15. David wang
    Dec 1, 2015
    29
    acording to your idea, the gtk package maybe need to be rebuild for uboobuntu .
  16. Francesco
    Jun 23, 2015
    220
    110
    If you want to use GPU-related features directly from GTK, yes.
    For instance QT has video player components. These components talk directly with the GPU to decode the video. If you just need to display widgets on the screen, you don't need to rebuild GTK.
