USB Wi-Fi dongle
Discussion in 'UDOO NEO' started by Narzhan, Feb 2, 2016.
  1. Narzhan
    Narzhan New Member
    Dec 8, 2015
    I'd like to connect a USB wi-fi dongle to Udoo to extend its features. But when I connect the usb to the board it idicates that it is connected but I can't see any new interface with ifconfig or iw. I tried two usb wifi with same result. I used lsusb for both of them and I can see that the usb is indeed connect, so I tried to install the drivers for both of them. They both use Ralink drivers so I tried to install the whole ralink driver package using:apt-get install firmware-ralink, but again no new interfaces. I tried to install the individual drivers from ralink website but encoutered the problem with missing file:/lib/modules/3.14.28-udooneo-04206-g9e7d486/build:no such file or directory. Can someone help me I am really desperate to make this thing work.
  2. Francesco
    Francesco Active Member
    Jun 23, 2015
    220
    110
    Which UDOObuntu release are you using?
    Can you post your dmesg output?
  3. Narzhan
    Narzhan New Member
    Dec 8, 2015
    I am using version 3.14.28.
    Dmesg | grep -i usb output:
    [ 0.101721] usb_otg1_vbus: 5000 mV
    [ 0.101988] usb_otg2_vbus: 5000 mV
    [ 0.103353] usbphy_nop1.12 supply vcc not found, using dummy regulator
    [ 1.977244] usb_otg2_vbus: disabling
    [ 1.981036] usb_otg1_vbus: disabling
    [ 8.068487] 2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
    [ 8.075970] usbcore: registered new interface driver usbfs
    [ 8.077155] usbcore: registered new interface driver hub
    [ 8.094416] usbcore: registered new device driver usb
    [ 8.103767] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [ 8.174712] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
    [ 8.197496] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
    [ 8.198646] hub 1-0:1.0: USB hub found
    [ 8.509129] usb 1-1: new high-speed USB device number 2 using ci_hdrc
  4. Francesco
    Jun 23, 2015
    220
    110
    First, please note kernel 3.14.28 is used in older betas, RC1 provides kernel 3.14.56
    Then I suggest you to power on the board without your USB adapter and then check `lsusb` and `dmesg` (without any grep - how can you be sure that "usb" is in the output?)
  5. Narzhan
    Narzhan New Member
    Dec 8, 2015
    Well, I have upgraded kernel to 3.14.56 but with no difference.
    lsusb output:
    Bus 001 Device 003: ID 1737:0078 Linksys WUSB100 v2 RangePlus Wireless Network Adapter [Ralink RT3070]
    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    desg output relating the usb:
    [ 1000.079365] usb 1-1: new high-speed USB device number 3 using ci_hdrc
  6. Francesco
    Jun 23, 2015
    220
    110
    We do not have the modules for your wifi adapter. We will include the modules in the next kernel build.
  7. Narzhan
    Narzhan New Member
    Dec 8, 2015
    Cool, that sounds great. Thank you.
  8. bnt2025
    bnt2025 New Member
    Apr 21, 2014
    Are you just going the add the module for this adapter or for the most common ones. I am having the same problem with a TP Link wifi adapter.
  9. Narzhan
    Narzhan New Member
    Dec 8, 2015
    I'd like to ask a follow-up question. When will the next kernel build be released.
  10. Andrea Rovai
    There's no roadmap yet.
