Hello, Just wondering if I'm doing something wrong or if udoo neo doesn't support booting from network (yet)? Also it seems saveenv isn't working in u-boot? U-Boot 2014.04-15346-gedd0741 (Oct 27 2015 - 11:18:21) CPU: Freescale i.MX6SX rev1.2 at 792 MHz CPU: Temperature 45 C, calibration data: 0x5594cc69 Reset cause: WDOG Board: MX6SX UDOO NEO I2C: ready DRAM: 1 GiB MMC: FSL_SDHC: 0, FSL_SDHC: 1 *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Found PFUZE300! deviceid 0x30, revid 0x11 Net: CPU Net Initialization Failed No ethernet found. Normal Boot Hit any key to stop autoboot: 0 => bootp No ethernet found. => saveenv Saving Environment to MMC... Writing to MMC(0)... The SD card is locked. Can not write to a locked card. mmc write failed failed
See this thread, it works after some patching http://www.udoo.org/forum/threads/neo-u-boot-no-ethernet-found.2827
