Anybody who got the sata working on the Quad Udoobuntu 2.0 RC2?
Discussion in 'UDOO QUAD' started by lazy_mosquito, Apr 28, 2016.
  1. lazy_mosquito
    lazy_mosquito New Member
    Jun 28, 2015
    14
    HI,
    I tried everything to got the sata working with the Quad Udoobuntu 2.0 RC2. I tried it as explained in the manuals, both ways: for the Udoobuntu 2.0 and the Udoobuntu 1.1. I also tried all the different hacks i could find on the internet.
    Somebody found a way?
    Pieter
  2. sirrab
    sirrab UDOOer
    Jul 26, 2014
    264
    32
    I haven't with UDOObuntu 2.0 RC2, yet. It did work with older versions.
  3. lazy_mosquito
    Jun 28, 2015
    14
    Annoying, The serial connection finally is more stable in RC 2.0, but now i loose the sata and can't start my VNC server automatically at boot. When is this finally gone work as intended? Everytime we advance one step, we go 2 steps backwards somewhere else.
  4. Andrea Rovai
    Hi there, still have problems?
  5. sirrab
    sirrab UDOOer
    Jul 26, 2014
    264
    32
    I still do.
    But haven't put a lot of effort in to it.
  6. Andrea Rovai
    What is exactly the problem that you've experienced?
  7. sirrab
    sirrab UDOOer
    Jul 26, 2014
    264
    32
    Let's start with the correct way to set it up. The exact URL with the instructions. I have the small u-boot SD card set up. It would be nice to know what flavor (zImage, xImage, etc.)of the kernel the u-boot is looking for. In case someone wants to compile their own version. Which I have! :D The versions UDOO presents, didn't work either. I guess I should try it again, and document what I observe. Let me do this first.
  8. jdewilde
    jdewilde New Member
    Jan 10, 2015
    I had the same issue until i did the whole procedure from within a booted SD image.
    Previous attempts flashing the images from a windows machine all failed.
    First flashed a 16GB sd card with the latest image then loaded and logged in.
    Re-downloaded all the necessary files and went through the whole procedure.
    The only thing I added to every line in the tutorial was to put 'sudo' in front of all the commands (obvious of course :) )
  9. Andrea Rovai
    The post is about UDOObuntu 2 RC2. Have you tried UDOObuntu 2? On UDOObuntu 2 SATA boot works.
