Arduino CH340 driver
Discussion in 'Arduino IDE' started by Enrico Cirignaco, Apr 16, 2016.
  1. Enrico Cirignaco
    Enrico Cirignaco UDOOer
    Feb 15, 2016
    hi guys, I've try to connect another Arduino at my UDOO neo. I've try with an original Arduino uno and all work great.
    But if I connect an Clone Arduino with Serial/usb converter Chip CH340 the Arduino IDE not see my Board.
    I've write the command lsusb into the terminal and I have see my board: QinHeng Electronics HL-340 USB-Serial adapter.
    But the Arduino IDE not see the board.
    Any Solution?
    thank you
  2. alessandroAmedei
    alessandroAmedei New Member
    May 10, 2016
    Hi, do you solve your issue? Did you try to install ch340 driver for linux on udoo? I want to do the same thing with a mega2560 based on ch340 usb communication.
    Thank you!
  3. ektor5
    ektor5 Administrator Staff Member
    Jul 1, 2013
    97
    48
    Seems a known issue, did you try with a standard CP210x Serial to USB converter attached to TX0 RX0?
    Ek5
  4. Enrico Cirignaco
    Feb 15, 2016
    I haven't resolve the problem...
  5. Andrea Rovai
    Dear @Enrico Cirignaco, please be a little more specific than "I haven't solved the problem", so to help other people help you.
  6. Enrico Cirignaco
    Feb 15, 2016
    I found some driver for mac os x, windows and linux 32-64 but they didn't work with arm UDOO Neo's processor.
    So now I can't upload some sketch in any Arduino clone with my UDOO Neo.
    If you have any solution please share it with us.
    thanks Enrico.
  7. waltervl
    Did you do an
    sudo apt-get update / upgrade ?
    It looks like a general Linux issue so perhaps it is already solved with an Ubuntu update.
  8. Enrico Cirignaco
    Feb 15, 2016
    Now I have do sudo apt-get update & upgrade.
    But I still have the problem...UDOO don't see my Arduino uno.
  9. waltervl
    After some googling around it looks like a lot of Linux users have issues with these serial to USB converters. Also raspberry pi users who also use arm processor so it it not very likely that a solution is near. The only simple thing I found was to do "sudo modprobe ch341" but no guarantee that it works.
    The other option is to buy another Uno with a proper USB to serial converter.
  10. waltervl
