System clock reset without power
Discussion in 'UDOO 101' started by imouro, Nov 3, 2013.
  1. imouro
    imouro New Member
    Oct 23, 2013
    Hi!
    I see that the Udoo not have battery to maintain the system clock. When I disconnect the power supply of Udoo and plug it back to the time is set to Thu Jan 1 1970 01:0:00 GMT.
    Is there a way to put a battery to power the system clock only?
    Thanks!
  2. Lifeboat_Jim
    Lifeboat_Jim New Member
    Sep 16, 2013
    399
  3. imouro
    imouro New Member
    Oct 23, 2013
    Thanks Lifeboat_Jim
    My Udoo will not have internet connectivity always, I use a RTC connected to the Arduino, I ask to save knowing that Udoo has a clock, so I want to install a battery only for the system clock
    While not having internet connectivity shelved and process the data wrong.
    Best regards!
  4. Lifeboat_Jim
    Sep 16, 2013
    399
    That thread I linked covers two topics(network time & adding a battery for the RTC), they are a bit mixed together but if you read through you can separate them easily enough.
  5. josolanes
    josolanes New Member
    Oct 14, 2013
    64
    Yep, that was my thread/question Jim linked to - I did install a RTC since (a 3.2v CMOP battery with wiring/connector) and it holds time when power is lost and restored as I've tested it
