Udoo NEO M4 looses program after Ubuntu2.1 upgrade
Discussion in 'UDOO NEO' started by JackSilb, Oct 25, 2016.
  1. JackSilb
    JackSilb Active Member
    Nov 3, 2015
    100
    32
    Got it. Giving the rationale for the request would help us understand.
    Nobody else in the Udoo Team to take this one?
    I can help, but I will need instructions.
    How one with the board could do the test you are requesting?
    i.e., "add a "sync" between lines 154 and 155 in udooneo-m4uploader"
    Thanks,
    -Jack
  2. Francesco
    Francesco Active Member
    Jun 23, 2015
    220
    110
    First you need to find that file. For example run:
    find /usr | grep m4uploader
    in a terminal. The open the file for editing:
    sudo leafpad /path/to/the/file
    Add the sync statement , save the file and reboot using
    sudo reboot
    Then try to reproduce the bug again. Thank you !
  3. Cyril BOSSELUT
    Cyril BOSSELUT New Member
    Oct 30, 2015
    23
    14
    use "which udooneo-m4uploader" in place of "find /usr | grep m4uploader" (that's shorter)
    you can even find and open it in one line:
    sudo leafpad `which udooneo-m4uploader`
    waltervl and JackSilb like this.
  4. JackSilb
    Nov 3, 2015
    100
    32
    Hey fellows,
    Good news. It seems to work.
    I placed "sync" before the line 155 "fi"
    Uploaded a new code using the Arduino 1.6.12. MacOSX Yosemite.
    Waited ~5s
    Reset NEO
    The Arduino code on the M4 still runs.
    Few more tests
    Even when I press the reset , or remove the power (USB cable), on the Neo as soon as the Arudino IDE show the Done Uploading and M4 Sketch is running, it seems to work.
    Good job!
    Now to the Udoo Team to document this and hopefully an Ubuntu 2.1.1 release...
    Thanks,
    -Jack
    waltervl likes this.
  5. waltervl
    @Francesco I tested it too with the added sync in /usr/bin/udooneo-m4uploader and that seems to do the trick! No more empty m4last.fw files and running last compiled file every time after a hard reset. It also worked now for internal programming.
  6. Francesco
    Jun 23, 2015
    220
    110
    Thank you guys for the all tests you did! I have fixed it in git. On Wednesday when I'll be back we will release it on the apt-get repo.
    Cyril BOSSELUT and waltervl like this.
  7. Francesco
    Jun 23, 2015
    220
    110
    `apt update && apt dist-upgrade` will apply the fix.
  8. Cyril BOSSELUT
    Oct 30, 2015
    23
    14
    I've found that if the script takes time to start the mqx_upload_on_m4SoloX returns an error (even if the script is working correctly):
    UDOONeo - Waiting M4 Run, m4TraceFlags: 0000027F
    UDOONeo - Failed to Start M4 sketch: reboot system !
    as the copy of the binary in /var/opt/m4/m4last.fw is done after flashing this is never called. I've moved the copy part before flashing and now all work fine (as the script has passed compilation i don't care about flashing errors).
  9. JackSilb
    Nov 3, 2015
    100
    32
    I did the udo apt-get dist-upgrade.
    The program of M4 is not being lost after a reboot. Assuming the the correct files are being replaced, this is done.
    Will a new Ubuntu release come so fresh installs work out of the box?
    Thanks,
    -Jack
  10. Andrea Rovai
  11. JackSilb
    Nov 3, 2015
    100
    32
    Cool.
    I should be able to give it a try during the weekend.
    Thanks,
    -Jack
  12. Gorgo
    Gorgo UDOOer
    Nov 9, 2016
    159
    17
  13. Andrea Rovai
    Updated. Thanks for pointing it out.
