UDOO X86 buttons SW1/2
Discussion in 'UDOO X86' started by Eric Falsken, Apr 25, 2017.
Tags:
  1. Eric Falsken
    Eric Falsken New Member
    Apr 25, 2017
    19
    I've not been able to find the function for these anywhere.....
    There are 2 buttons: SW2 on the front of the board and SW1 on top, both located near the FRONT_PANEL and IR Sensor - Top Right in this image: [​IMG]
  2. Kilrah
    Kilrah Member
    Apr 20, 2017
    31
    16
    Next to SW1 you'll see "Rst" = Reset, SW2 "Pwr" = Power.
  3. Brad
    Brad New Member
    Apr 25, 2017
    Related to those buttons is the front panel connector. It has 9 pins where pins 5 & 7 are reset and 6 & 8 are for a power switch. I've been using the buttons since I have no case for this yet.
  4. FirstGenGeek
    FirstGenGeek Member
    May 25, 2016
    66
    26
  5. Eric Falsken
    Apr 25, 2017
    19
    Ah, so it is RST only for the Arduino, and not the Intel, correct?
    The power button, I'll have to play with.
  6. FirstGenGeek
    FirstGenGeek Member
    May 25, 2016
    66
    26
    I tried pressing SW1 from the BIOS screen, within Ubuntu, in apps, and it has no effect. So it looks like it is used only to Reset/Run the Arduino side of the board.
  7. x1800MODMY360x
    x1800MODMY360x Member
    Mar 29, 2017
    55
    On the pin header there is a reset, not sure if its for the arduino or the main board itself.
  8. fabio978
    fabio978 Member
    Jul 2, 2014
    51
    It's just a power button ;)
  9. Brad
    Brad New Member
    Apr 25, 2017
    Search for RSTBTN# and PWRBTN# on the schematic. These buttons route to both the Braswell SoC and the STM32F. Page 29 of the user manual describes it as well.
  10. fabio978
    fabio978 Member
    Jul 2, 2014
    51
    Here it is described as "Arduino master reset". I didn't try by myself so i don't know what it actually resets.
  11. Brad
    Brad New Member
    Apr 25, 2017
    I read what @fabio978 sent and tried it.
    I was successfully running one of the IMU programs then I hit the master reset and the IMU data stopped. Sounds good but I'm not sure what actually happens to the STM32F.
    So, I restarted the Arduino IDE and tried to upload the sketch. It was having problems (see the attached message) and the IDE asked me to hit the master reset. When I did, I saw COM3 removed and added back to the Windows device manager list. Then the sketch was successfully uploaded.
  12. 3Rton
    3Rton New Member
    Sep 16, 2017
    Where can I find the layout of the front panel header pins (mainly which pins equal what connections.)
  13. itimpi
    itimpi UDOOer
    Oct 31, 2013
    136
    39
    Look under Resources->Docs x86->Downloads for the User Manual which has this information in it.
    3Rton likes this.
  14. Eric Falsken
    Apr 25, 2017
    19
    As itimpi said. The PDF download has a LOT more in it than the wiki.
