startup problem, no graphical screen
Discussion in 'UDOO X86' started by imbrattabit, May 12, 2017.
Tags:
  1. imbrattabit
    imbrattabit New Member
    May 12, 2017
    system doesn't start properly I guess, nothing is showing but this message:
    "EFI Shell version 2.40 [21793.17]
    Current running mode 1.1.2
    Device mapping table
    blk0... to blk5
    Press ESC in 1 seconds to skip startup.nsh, any other key to continue
    only power cable, hdmi cable and keyboard (working) is plugged to the board.
  2. ImLagging
    ImLagging Member
    May 9, 2017
    73
    28
    Have you installed an OS? If so, which one? Are you currently trying to install an OS?
  3. imbrattabit
    May 12, 2017
    I haven't installed an OS yet, it's just the very first boot, I expected to see the drives selection as showed in the video tutorial
  4. imbrattabit
    May 12, 2017
    nevermind, I just typed "exit" and accessed to device and boot management :)
  5. Markus Laire
    Markus Laire Active Member
    Mar 9, 2017
    225
    92
    To get directly into BIOS without that shell you need to press ESC sooner. Try pressing ESC repeatedly starting immediately when UDOO is powered.
  6. imbrattabit
    May 12, 2017
    pressing ESC didn't work, maybe because I'm using a wireless keyboard.
    Anyway, now Udoo is working like a charm :)
  7. Markus Laire
    Mar 9, 2017
    225
    92
    Yes, others have reported in forum that wireless keyboards can be so slow to start up that they can't be used to press ESC quickly enough.
  8. ImLagging
    ImLagging Member
    May 9, 2017
    73
    28
    I don't have a way of testing this myself, but you can set the UDOO logo to display for X number of seconds within the bios. This might provide enough of a delay for wireless keyboards. Maybe someone else can test this and post the results?
  9. imbrattabit
    May 12, 2017
    thanks, I'll try it
