Hey there, just received my udoo x86 and got a few things up and running with should replace my bananapi in the future. But I'm not quite sure, if this next step is possible... On my bPi, i've connected a 433Mhz transmitter ( https://www.sparkfun.com/products/10534 ) and installed wiringPi for sending signals. Do you think, that this is possible to adapt on an udoo x86? Do I have to use the arduino-parts or can I directly control the GPIO Pins, like in wiringPi? In my case it's GPIO17. Thank you for your answers My current setup: Debian Stretch with a LAN --> WiFi-bridge using hostapd and bridge-utils
It doesn't look like you can just plug this transmitter right into any Arduino, to me it looks like it would just claim four random pins. You can use male-female Dupont wires to wire the pins to the Arduino.
Thank you for the reply. I already own these wires - can try it later. Is it possible to use the GPIO17, which is mentioned here https://www.udoo.org/docs-x86/img/x86_pinout_arduino.png ? My planned cabling is: +5V, Ground and GPIO17 like it was on my bPi. But not sure, if it works...
According to datasheet it can work with 3-12V VCC. Since Arduino 101 used in UDOO X86 uses 3.3 V signals, it might be best to use 3.3 V as VCC instead of 5V.
Also note that INNER pins like shown in your image are controlled by Arduino. These have 3.3 signal voltage (but can be safely used with 5 V input signals). OUTER pins are then controlled directly by main CPU but they use 1.8V so are not compatible with your transmitter. So it seems that you have to either use Arduino pins, or if you want to use direct pins then you would need voltage level translation in between.
@Markus Laire Thank you for the advice! So it's okay to use the GPIO17? I'm pretty interested in trying wiringPi commands, like "send" for switching remote power plugs via the udoo. But this was on my bananapi, so I don't think, that this will work... But I'll give it a try. I expect, that either the compiling or the using of wiringPi https://git.drogon.net/?p=wiringPi;a=summary will fail...
GPIO17 (or any other) should work as long as the Arduino library you use supports that. You could try to create an Arduino sketch which takes inputs from UDOO via serial and then relays them to transmitter.
Ok, couple things here... 1) Talking to the Arduino pins is somewhat different than talking to the GPIO pins on a Ras/Banana Pi. You can't directly do it via Python or WiringPi. 2) Talking to the GPIO pins controlled by the CPU is more in line with what you were doing on the Pi, but you have to deal with the voltage levels being significantly different, and you need some sort of API to talk to (which I don't know about for the CPU... )
Hi all, thank you very much for your help! I got it working rudimentally. Here's what I've done (after installing Arduino IDE 1.8.2 and the Arduino 101 board definitions): - Cabling: 3.3v, Ground and Pin4 (The left ones, including GPIO17 are analogue in and might not work properly) - Installed the rc-switch library via the Arduino IDE library manager (Ignore the warning, that it's not compatible with the Arduino 101) - Written the code - more or less by myself (had some really good help from my girlfriend) Here's "my" code - which isn't perfect. Having some trouble when sending 2 commands with a too short waiting time. Have to reboot for getting it back working. Code: #include <RCSwitch.h> RCSwitch mySwitch = RCSwitch(); char code; void setup() { mySwitch.enableTransmit(4); Serial.begin(9600); delay(1000); } void loop() { while(Serial.available() <= 0){ delay(10);} code = Serial.read(); if (sizeof(code) == 1) { switch(code) { case '0' : mySwitch.switchOn("11111", "01000"); break; case '1': mySwitch.switchOff("11111", "01000"); break; case '2': mySwitch.switchOn("11111", "00010"); break; case '3': mySwitch.switchOff("11111", "00010"); break; default: break; } } } Now the commands can be executed by sending the numbers to the ttACM0, for example: Code: echo '1' > /dev/ttyACM0
For some inspiration what you can do with an Arduino and rf transmitters you can go to https://www.mysensors.org/
@waltervl Thank you for this link, but I currently have just a RF sender, not a receiver... But I think it might be possible with a receiver like this http://www.ebay.com/itm/5Pcs-433Mhz...link-kit-for-Arduino-ARM-MCU-WL-/130732506374
I went straight for the transceivers, as they have both a transmitter and a receiver. In my home project I'll switch to XBee (ZigBee). In my opinion WiFi is too unreliable.
For the inner pins (ie: pins 0-7) of the x86 101, I'm getting a low reference voltage of 1.2VDC instead of zero. Is this correct? Shouldn't the low/ground reference be closer to zero?
You should check with Arduino 101 (curie) documentation what is the threshold for digital pins. In this link someone had the same experience as you on a normal Arduino 101. He measured 1.26V threshold. https://arduino.stackexchange.com/questions/38939/arduino-101-i-o-voltage-levels
Arduino 101's IO pin, when set to output mode, if not driving the heavy load (within the spec), should be 0V on logic 0 and about 3.3V on logic 1. In the case of input mode, the voltage level is determined by external signal driving that pin.
