I am trying to build an Android image(version 6.0.1) from source following the manual but I have trouble syncing successfully. I keep getting Is the build broken? Also I see there is Android 7 tag available from Udoo. Can I use it?
I managed to get through this error by using the known issues section. I drop it here in case someone has the same problem. I also needed to apply the changes mentioned here and run the following:
As I said to my previous post I managed to get Android working. I used the sdcard flashing script to create a bootable sdcard. Is there any way to create a .img like the one provided in download section?
