Hello everybody, I'm looking for a good RTOS that can be used with UDOO quad. Has anyone tried one and found it good? It's highly recommended if the RTOS is free and highly appreciated if you support any link for the RTOS you recommend, its installation or any projects made using it. Thanks in advance.
Not that I can advise you personally but you have to indicate on what processor of the Udoo Quad you want to run the RTOS as the Udoo Quad has 2: NXP® i.MX6Quad, 2\4 x ARM® Cortex™-A9 core @ 1GHz with ARMv7A instruction set Atmel SAM3X8E ARM Cortex-M3 CPU (same as Arduino Due) Perhaps RIOT seems to be interesting as it notes Udoo board (Cortex M3) as supported: http://www.riot-os.org/#usage
Thanks for your reply and sorry for forgetting that. I want to run it on Udoo Quad using NXP® i.MX6Quad, 4 x ARM® Cortex™-A9 core @ 1GHz with ARMv7A instruction set
That is a little bit strange given the fact that the Udoo Quad CPU Atmel SAM3X8E ARM Cortex-M3 CPU (same as Arduino Due) is designed to do RTOS stuff.....
