UDOO x86 weight
Discussion in 'UDOO X86' started by ssbl, Jul 19, 2017.
  1. ssbl
    ssbl New Member
    Jul 19, 2017
    Does anyone know the exact weight of the board? I was wondering if it's light enough to be mounted on a not-so-large drone.
    Markus Laire likes this.
  2. walder
    walder New Member
    Jul 14, 2017
    My X86 Advanced is 116.6 grams (measured with precision scales)
    waltervl and Markus Laire like this.
  3. Maurice
    Maurice Active Member
    Oct 13, 2015
    394
    87
    Battery powering it might be an issue. Won't a Neo suffice? Though the Arduino programming part might be much more difficult as the Neo isn't so 'Arduino compatible'.
  4. ssbl
    ssbl New Member
    Jul 19, 2017
    Thanks!
    You're right, I'll need a 12v 3a battery as well I think. I found another thread here which mentioned this one http://www.lynxmotion.com/p-727-120-volt-ni-mh-2800mah-battery-pack.aspx
    I want to attach a particular WiFi card on the board, so the M.2 E-key slot is pretty crucial. If I'm not wrong the Neo doesn't have this slot.
  5. Markus Laire
    Markus Laire Active Member
    Mar 9, 2017
    225
    92
    You probably don't need anywhere near 3A, that recommendation has a lot of margin for connecting USB devices etc.
    Also that battery pack doesn't seem to have regulated output, UDOO requires 12V +- 5%.
  6. jas-mx
    jas-mx Active Member
    Dec 31, 2013
    407
    118
    What your plans for the flight controller as the Ardunio doesn't seem to be the ideal h/w?
  7. ssbl
    ssbl New Member
    Jul 19, 2017
    For now the plan is to not use the board as the flight controller.
