Speaker Headers
Discussion in 'UDOO X86' started by Eric Falsken, Aug 19, 2017.
  1. Eric Falsken
    Eric Falsken New Member
    Apr 25, 2017
    19
    What is the name of the speaker jack header on the X86 board? I'd like to use it for my project instead of the 3.5mm (headphone) output.
  2. Maurice
    Maurice Active Member
    Oct 13, 2015
    394
    87
  3. waltervl
    LDighera and Markus Laire like this.
  4. Eric Falsken
    Apr 25, 2017
    19
    OMG Thanks! Never would have found this!
  5. Eric Falsken
    Apr 25, 2017
    19
    Would be really sweet if they put stuff like this in their doc/spec/wiki. Especially for a board that is meant for makers. How do I tag an admin?
  6. waltervl
    They have put this stuff in the manual (pdf) see the linked pdf in the post of Maurice, section 3.3.5.
    This information should be enough to order the required connectors. I just helped you. And when you search the forum for these part numbers you would have found the ebay link yourself (it was the way I did it) :)
    Laura likes this.
  7. waltervl
    Although @Laura it would be easier (I mentioned it before) that the content of this user manual PDF should be added to the HTML part of the documentation. It is very confusing to find one part of the documentation online and the other part in a pdf (that changes without notification)
  8. Eric Falsken
    Apr 25, 2017
    19
    Ah. I never knew the PDF existed or was different. Thanks for the clarification. These days, I expect the wiki online doc was the same and the whole of the available resources. Forums are not good sources of documentation or for distributing official resources. (especially since the contents of the PDF attachment don't show up in a "search" of the forums.)
    Thanks for pointing me at the PDF.
    waltervl likes this.
  9. waltervl
    @Laura another good reason....
  10. Laura
    Laura UDOOer
    Apr 22, 2016
    374
    156
  11. Uberbot
    Uberbot New Member
    Sep 28, 2017
  12. waltervl
