HI, thanks for tutorial. I followed all tutorial to create bsp file. so when I tried this command zcat tmp/deploy/images/udooneo/******.gz | sudo dd of=/dev/sdd bs=16M I cant find *.gz file but *.bz2 about 113 MB, like this udoo-image-full-cmdline-udooneo-201712072245.rootfs.wic.bz2 in /build/tmp/deply/image/udooneo
HI, Yesterday I created and installed the yocto distro on my UDOONeo without x11. So, now I somebody can explain me can how I do autologin? two, I tried to compile QT sdk but I recevied some error: Code: simone@UbuntuVB:~/udoo-community-bsp/build$ MACHINE=udooneo bitbake udoo-image-qt5 -c populate_sdk WARNING: Host distribution "Ubuntu-16.04" has not been validated with this version of the build system; you may possibly experience unexpected failures. It is recommended that you use a tested distribution. Loading cache: 100% |###########################################| ETA: 00:00:00 Loaded 2570 entries from dependency cache. NOTE: Resolving any missing task queue dependencies Build Configuration: BB_VERSION = "1.30.0" BUILD_SYS = "x86_64-linux" NATIVELSBSTRING = "universal" TARGET_SYS = "arm-poky-linux-gnueabi" MACHINE = "udooneo" DISTRO = "poky" DISTRO_VERSION = "2.1.3" TUNE_FEATURES = "arm armv7a vfp thumb neon callconvention-hard cortexa9" TARGET_FPU = "hard" meta meta-poky = "HEAD:1083d90888589b9f0d50a1d480f7c774d8b4bda3" meta-oe meta-python meta-networking meta-multimedia meta-ruby = "HEAD:55c8a76da5dc099a7bc3838495c672140cedb78e" meta-fsl-arm = "HEAD:e2254e7b2ded0c2b66b1226f879b3a6d52037b2d" meta-fsl-arm-extra = "HEAD:2c28e636ec15c2cfd49bc9cebe0bbbcfde95bc7b" meta-fsl-demos = "HEAD:a165068f8a0d1cf29aabe4b4053f28be1c2aa492" meta-udoo = "HEAD:a01cfce52c52fc942eab4375cd249795ca24c53f" meta-qt5 = "jethro:ea37a0bc987aa9484937ad68f762b4657c198617" NOTE: Preparing RunQueue NOTE: Executing SetScene Tasks NOTE: Executing RunQueue Tasks WARNING: qtserialbus-5.5.1+gitAUTOINC+04b75569f3-r0 do_fetch: Failed to fetch URL git://github.com/qtproject/qtserialbus.git;branch=5.5, attempting MIRRORS if available ERROR: qtserialbus-5.5.1+gitAUTOINC+04b75569f3-r0 do_fetch: Fetcher failure: Unable to find revision 04b75569f36eec14662505a08bf8c1d565cb10fe in branch 5.5 even from upstream ERROR: qtserialbus-5.5.1+gitAUTOINC+04b75569f3-r0 do_fetch: Function failed: Fetcher failure for URL: 'git://github.com/qtproject/qtserialbus.git;branch=5.5'. Unable to fetch URL from any source. ERROR: Logfile of failure stored in: /home/simone/udoo-community-bsp/build/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/qtserialbus/5.5.1+gitAUTOINC+04b75569f3-r0/temp/log.do_fetch.15165 ERROR: Task 356 (/home/simone/udoo-community-bsp/sources/meta-udoo/qt5-layer/recipes-qt/qt5/qtserialbus_git.bb, do_fetch) failed with exit code '1' thanks.
@Simone I did build Yocto for the Seco-A62 with Qt5.9 so its a newer version but I also had compile errors on the qtserialbus. I didn't need it so I removed the qtserialbus_git.bb from @graugans recipe and rebuild. This worked for me. You can find this in: meta-udoo/qt5-layer/recipes-qt/qt5/
Hello , I got problem when built helloworld example for QT5 by QTCreator as: " main.o.qtversion[qt_version_tag]+0x0): undefined reference to `qt_version_tag' " I have checked qmake version by command : qmake --version and the result as bellow: "QMake version 3.0 Using Qt version 5.6.3 in /opt/poky/2.1.3/sysroots/cortexa9hf-neon-poky-linux-gnueabi/usr/lib" Who can recommend the any idea for me? Thanks advance!
Hello there, after a year Can one person please describe me how can I build a yocto for my UDOO Neo board?? All links are broken, always failures, errors errors and errors... I just want to execute my lovely application on a UDOO Neo board. Why this is so hard Sorry for being a noob btw. Things I tried: Try to build a qt version for UDOObuntu (a billion times) Give up and try to build a Yocto for UDOO (a million times) Give up and use the ready image builded by @modjo (@graugans your links are all broken) (my application worked well with the build that shared by @modjo but lvds7 touch panel doesn't work and there is no gstreamer installed and I need them both) Please help me guys, I am about to go crazy!
Hi there! Really appreciate this tutorial. I want to clarify one thing: in order to build yocto image can I use virtual machine or does it have to ba a native linux machine?
