Have a look at http://www.freescale.com/webapp/sps/sit ... _Tools_Tab and there are Freescale documents and posts about it.
hi, I know how to use the MFG-Tool. My question is, can it used to transfer software to the I.MX on the UDOO. Because, if the Boot pins set to another boot option, the MFG-Tool can't be used.
boot pins.. the resistors you mean. Hmm, I see your point. Still if you're brave you can alter those (assuming you don't value the warranty).
Hi, I tried mfgtool but it doesn't work, I think that mfgtool uses a custom configuration for mx6 custom board (sabresd, sabrelite) that doesn't match with udoo,so, this tool doesn't work.
