Is anybody working on porting BackTrack5 on Udoo?
Discussion in 'Application & Utilities' started by javax, Nov 14, 2013.
  1. javax
    javax New Member
    Oct 23, 2013
    10
    Either Android or Ubuntu version of BackTrack5 R3?
    Just wondering since I don't have the hardware yet to play with it.
  2. Lifeboat_Jim
    Lifeboat_Jim New Member
    Sep 16, 2013
    399
    Not heard anyone mention it.
    I see BackTrack5 vanilla (IE not R1, R2 or R3) is available for ARM. Not very encouraging that R1-3 doesn't have ARM support... indicates they dropped that some time ago, perhaps ran into problems? Worth checking their forums for this and discover the background to that decision.
    Although this is an Open Source GPL'd project, I don't see the source code.
    Caveat: I spent 30 seconds looking at their site. If you have the source code, you can just compile it yourself.
  3. mr_clark
    mr_clark New Member
    Nov 3, 2013
    Probably makes more sense to put effort into testing Kali Linux since Backtrack is really not being supported anymore and Kali does have support for ARM.
    http://www.kali.org/downloads/
  4. javax
    javax New Member
    Oct 23, 2013
    10
    You are correct. It makes more sense to use Kali now.
    Although I was a long time BackTrack user (inactive for more than a year), I must have missed something in-between. Kali is the successor to BackTrack and even it uses the same logo as the old BackTrack's.
    I will have to play with Kali once I receive my Udoo.
  5. delba
    Right now we're not working on porting BackTrack or Kali on UDOO (officially). If anyone will be able to do that, please share ;)
  6. Wally88
    Wally88 New Member
    Jun 9, 2013
    First things first, i don't speak English so i'll do my best
    I've ported Kali to my Udoo Quad, on a 320gb sata hdd, i've been trying since i got udoo on my hands, but yesterday, finally, i've made a good install but there are some things left to do like installing vivante modules and so, i don't have much free time to do this, so maybe i'll share with all of you the image so you can continue my work.
  7. Lifeboat_Jim
    Sep 16, 2013
    399
    Great, many thanks Wally :)
  8. delba
    That's nice Wally, thanks in advantage to share your work with us.
  9. javax
    javax New Member
    Oct 23, 2013
    10
    Wally88,
    Did you, by chance, upload the Kali image for Udoo to somewher? If you don't mind, could you make it available for us to download? I have tried to build the Kali image on my Udoo last night unsuccessfully and I was thinking about trying it again tonight.
    Thanks.
  10. javax
    javax New Member
    Oct 23, 2013
    10
    Better yet, if you could publish the steps you went through to install Kali Linux on Udoo, I can at least compare yours with mine to see what I was doing wrong.
    Thanks.
  11. buggz
    buggz New Member
    Nov 25, 2013
    Hello,
    Wally88,
    Yes please post how to do this.
    While it would be nice to have an image available, I'd also like to know how to perform the steps to build this.
    Thanks!
  12. Wally88
    Wally88 New Member
    Jun 9, 2013
    Hi all, sorry for make you wait, i'll upload the image in a few hours, i'm at work right now.
    The image it's made for armhf, almost everything it's working, even analog and hdmi audio, but there is software graphics only, i can't make Vivante work yet.
    I'll write a simple guide for you to make your own Kali for UDOO too.
    Again, sorry for my bad english
  13. Lifeboat_Jim
    Sep 16, 2013
    399
    Thanks Wally
    Don't worry about the Vivante at this stage, I'm confident that others can assist there in the coming weeks.
  14. miousername
    miousername New Member
    Jun 23, 2013
    73
    Which is the xorg version of your kali?
    I could help you to install Vivante acceleration :)
  15. Wally88
    Wally88 New Member
    Jun 9, 2013
    To make it simple and easier, create the image from a Kali or Debian base system with armhf or armel (depends on what you want) you only need debootstrap installed on that base system. (yes, i done the entire system from UDOO)
    If it isn't installed run:
    apt-get install debootstrap
    Create base system, add kernel and modules
    cd /root
    mkdir kali
    debootstrap --arch=armhf kali /root/kali/ http://http.kali.org/kali
    cd kali/boot
    wget http://udoo.org/download/files/UDOO_Unico/Kernel/uImage
    cd ..
    wget http://udoo.org/download/files/UDOO_Unico/Kernel/modules.tar.gz
    tar xvzf modules.tar.gz
    rm modules.tar.gz
    Some modifications:
    nano etc/network/interfaces
    At the end of the file, add:
    auto eth0
    iface eth0 inet dhcp
    add dns servers
    nano etc/resolv.conf
    nameserver 8.8.8.8
    nameserver 8.8.4.4
    nano etc/hosts
    and here you've to add this line after the first one
    127.0.1.1 Kali
    Set hostname:
    echo 'Kali' > etc/hostname
    Add repos:
    nano etc/apt/sources.list
    deb http://http.kali.org/kali kali main contrib non-free
    deb http://security.kali.org/kali-security kali/updates main contrib non-free
    deb-src http://http.kali.org/kali kali main contrib non-free
    deb-src http://security.kali.org/kali-security kali/updates main contrib non-free
    Set root password:
    cd ..
    chroot kali
    passwd root --> what you want, i use "toor"
    exit
    To get serial console
    cd kali
    nano etc/inittab
    At the end of the file add:
    T1:23:respawn:/sbin/getty -L ttymxc3 115200 vt100
    And with that you can already boot the system
    Once inside:
    apt-get update
    apt-get install firmware-ralink wpasupplicant ntp openssh-server
    dpkg-reconfigure tzdata (to correct timezone)
    /etc/init.d/ntp restart
    update-rc.d ssh enable
    And here it's the most important and simplier command:
    tasksel (here, select everything but laptop utilities)
    apt-get install bluetooth kali-linux-full kali-menu (to make sure nothing it's missing)
    nano /etc/network/interfaces
    delete what we add earlier
    reboot
    and here you have a full kali linux on UDOO
    It's my first guide and i write it from memory, i think it doesn't but it may have some error, if some moderator wants to make it more readable, please be my guest.
    TODO: Vivante, Arduino UDOO IDE, add ext4 and ntfs support (kernel recompile)
  16. matthias
    matthias New Member
    Oct 23, 2013
    Hi miousername,
    maybe you could post a guide on how to get the vivante acceleration working on a armhf-system?
    i know several people working on getting that to work - so it would probably help for different systems.
  17. Wally88
    Wally88 New Member
    Jun 9, 2013
    Hi, thanks!!
    it's Xorg 1:7.7+3~deb7u1
    By the way, glxinfo says:
    but also says:
    and glxgears runs at ~65 fps
  18. javax
    javax New Member
    Oct 23, 2013
    10
    I used a slightly different approach to create a Kali FS successfully also on Udoo last night. I will try to make it bootable tonight. and let you guys know how it goes Perhaps it would be useful to create a full installation script (bash or ksh)...
    Thanks.
  19. Wally88
    Wally88 New Member
    Jun 9, 2013
    Hi!
    I've tried another ways but only the one i use gives me the same as kali live dvd.
    Can i ask how you do it? Please share.
    Thanks!
  20. miousername
    Jun 23, 2013
    73
    Ok they are installed but serms that glxgear/glxinfo don't use openGL Vivante libraries!
    Trace glxgears with :
    strace -e open -f glxgears
    to drbug if glxgears use the correct libraries you installed! ;)
