Then something is wrong with your board or you are not measuring correctly. Are you putting 1 measuring pen on pin gnd and 1 on 5V? Does your Neo boot? If you load the Arduino blink example does your led blink?
yes, but i dont go used arduino i need to test for use with linux or android this port for active gps
