Video Inputted thru HDMI
Discussion in 'UDOO QUAD' started by Patrick Peters, Mar 27, 2018.
  1. Patrick Peters
    Patrick Peters New Member
    Mar 27, 2018
    Hello I have a project that I am working on, and I like to bring video in thru the HDMI (vs it being an output only) then send the signal via Wifi.
    Is this possible?
    The problem will be HDMI input as that is normally not supported. But perhaps on the Udoo Quad it is.
    You can transmit/stream video over wifi or whatever network but you have to find another input mode. The easiest way would be USB (like a webcam).
    If you look around there are HDMI input to CSI (Udoo Camera) interfaces that perhaps could work. but you will need some hardware and csi driver knowledge example: https://auvidea.com/b100-hdmi-to-csi-2-bridge/
  3. Patrick Peters
    Mar 27, 2018
    How about the MIPI on the UDOO Quad, can that be configured as an Input rather than an output?
