Hi, Is it possible to connect other I2C sensors (in my case a BME280 from Adafruit) to the I2C of the brick? Is there somewhere a description what the five cables are, that lead into the brick? Are these also SCK and SDI connectors? Thanks for your help!
Refer to page 35 of the manual for pin information: http://download.udoo.org/files/UDOO_X86/Doc/UDOO_X86_MANUAL.pdf The mating connector is also explained on that page if you would like to connect to the Brick socket on the board. The other option is to connect the wires to the I2C pins on the standard I/O header
Thanks for your fast help. I will connect it over the I/O headers. I just needed to know the pinout. Thanks!
The Bricks are 3.3V. Do not connect them to a 5V source. If the BME280 from Adafruit module you mentioned is this one https://www.adafruit.com/product/2652, it can be connected to the 3.3V power and I2C bus.
Yes I know that the BME280 can handle 3.3V and 5V. Unfortunately I want to attach on the same power supply an anemometer that requires 5V. So I will see that I can transform the 5V before the brick sensor to 3.3 V. Thanks for your help!
Thanks for all your replies. I realized that the BME280 from Adafruit can have 3.3V or 5V input and also, that it has a 3.3V output. This solves my problem properly.
