probably yes, but you will need an external power supply for the hard disk, since the board does not provide the 12v on the sata power connector.
Thank you. Yes I figured as much with the power supply. I'll be building a splitter to supply the board and drive. It's just the 10TB drive, not sure all boards can address the drive properly.
