issues on Linux Kernel compilation for SBC A62
Discussion in 'SECOSBC-A62' started by MatteoZ, Sep 11, 2018.
  1. MatteoZ
    MatteoZ New Member
    Apr 24, 2017
    I have recently found issues in compiling the Kernel code branch downloaded from
    https://github.com/UDOOboard/linux_kernel -> branch imx_3.14.28_1.0.0_ga_a62.
    I am following the instructions posted at the link: http://download.udoo.org/files/a62/UDOObuntu2/instructions_kernel_compiling.txt
    I was previously able to go through the kernel compilation steps without any issue.
    I have recently set-up a new Ubuntu 16.04 LTS PC, identical in configuration as the previous one where the compilation is still working fine. The only difference is that I have downloaded fresh code from the https://github.com/UDOOboard/linux_kernel on the new PC.
    Here the process I am following:
    git clone https://github.com/UDOOboard/linux_kernel
    cd linux_kernel/
    git checkout imx_3.14.28_1.0.0_ga_a62
    make ARCH=arm seco_a62_defconfig
    make ARCH=arm menuconfig
    make -j8 CROSS_COMPILE=arm-linux-gnueabihf- ARCH=arm zImage modules dtbs
    If I avoid to checkout the github using the imx_3.14.28_1.0.0_ga_a62 branch, the compilation succeed.
    If apply the git checkout to imx_3.14.28_1.0.0_ga_a62, the compilation is crashing with the following error messages:
    cache-l2x0.c:(.text+0x974): multiple definition of `nop_dma_unmap_area'
    arch/arm/mm/dma-mapping.o:dma-mapping.c:(.text+0x1314): first defined here
    scripts/Makefile.build:387: recipe for target 'arch/arm/mm/built-in.o' failed
    make[1]: *** [arch/arm/mm/built-in.o] Error 1
    Makefile:843: recipe for target 'arch/arm/mm' failed
    make: *** [arch/arm/mm] Error 2
    I am attaching a log file with the entire collection of error messages.
    If I try to compile the kernel without the git checkout required for the SBC A62, staying with the main Udoo branch, the compilation completes successfully.
    Is it possible for the Udoo code developers to check potential inconsistencies in github.com/UDOOboard/linux_kernel?
  2. MatteoZ
    MatteoZ New Member
    Apr 24, 2017
    I have fixed the issue. The Linux iMX6 3.14.28_1.0.0_ga_a62 kernel compile process described in the Udoo documentation works flawless only if a PC with Ubuntu 14.04 LTS is used. I am not sure if others were able to fix it on Ubuntu 16.04 or later distributions. Apparently if the compile is done at least once with the 14.04 LTS, the distribution can be updated to 16.04 and it keeps working on. I am not sure if this is related with the package dependencies that have been resolved previously when the 14.04 was in use.
    waltervl likes this.
