Hi all, Maybe a stupid question but is there any way how to resize online mmcblk0p1 which is mounted to / so I can fully use the size of my card? thx
Disk /dev/mmcblk0: 33.2 GB, 33201061888 bytes 101 heads, 2 sectors/track, 321018 cylinders, total 64845824 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk identifier: 0x00013be1 Device Boot Start End Blocks Id System /dev/mmcblk0p1 16065 7749631 3866783+ 83 Linux Command (m for help): d Selected partition 1 Command (m for help): n Partition type: p primary (0 primary, 0 extended, 4 free) e extended Select (default p): p Partition number (1-4, default 1): 1 First sector (2048-64845823, default 2048): 16065 Last sector, +sectors or +size{K,M,G} (16065-64845823, default 64845823): Using default value 64845823 Command (m for help): t Selected partition 1 Hex code (type L to list codes): 83 Command (m for help): w The partition table has been altered!
Hi, I think maara forgot to add a reboot to make Linux reload the partition table. And execution of command: resize2fs /dev/mmcblk0p1 to enlarge filesystem. Cheers Giuseppe
You are right - these steps are not written here but I did them. I only forgot to copy and paste them here but they are a definitely "must do" part of the resize process.... Thanks for heads up!
