hi, in order to try to make the bord going (it not display anything) I want to try a bios reset (as the bord had a firmware update before being sending, maybe the bios is in a configuration that not like my memory modules). On page 44 of manual it is decribed a 3 way switch for reset the Bios, but I did not find in on the board. Can someone point to that switch? Thanks
Hi Stefano, The switch is located on the bottom face, right side. Please refer to this guide on how reset the BIOS with the switch: https://www.udoo.org/docs-bolt/Hardware_References/BIOS-UEFI_Firmware.html BR, Ek5
Hi, find thanks (I suppose it was insider the board, not at the external side). For the one that has the board that did not works, look at that switch at it was set to reset bios by default.
