QT5 | No Decoder Available Error | Udoobuntu | QMediaPlayer
Discussion in 'UDOO NEO' started by closx, Jun 1, 2019.
  1. closx
    closx UDOOer
    May 2, 2019
    Hello all, it is me again :D
    Since nobody is responding to my questions, I am trying to solve my problems very randomly.
    So, now I can run my QT application on Udoobuntu, but no video visuals.
    It gives that error,
    Warning: "No decoder available for type 'video/x-msvideo'."
    How do I install a decoder for an .avi video to Udoobuntu?
    Full error output,
    Starting /home/udooer/Downloads/build-VideoPlayer-Desktop-Release/VideoPlayer...
    xkbcommon: ERROR: x11: failed to get keymap from X server: unmet condition in get_explicits(): wire->keycode >= keymap->min_key_code && wire->keycode <= keymap->max_key_code
    Warning: EGL suggested using X Visual ID 33 (RGB888) for EGL config 1 (RGB444), but this is incompatable
    Unable to find an X11 visual which matches EGL config 1
    (VideoPlayer:5786): GStreamer-CRITICAL **: gst_object_ref: assertion 'object != NULL' failed
    (VideoPlayer:5786): GStreamer-CRITICAL **: gst_object_sink: assertion 'GST_IS_OBJECT (object)' failed
    GStreamer; Unable to play - "file:///home/udooer/video/video.avi"
    Error: "Your GStreamer installation is missing a plug-in."
    Error: "No URI set"
    Error: "No URI set"
    Error: "No URI set"
    Error: "No URI set"
    /home/udooer/Downloads/build-VideoPlayer-Desktop-Release/VideoPlayer exited with code 0
  2. closx
    closx UDOOer
    May 2, 2019
    Okay everyone, I finally got what is wrong.
    UDOO NEO CANNOT PLAY VIDEOS!
    Processor of Udoo Neo (imx6something) does not support video decoding. So there is no decoder. You can only play very small video files (like 100px400p 10fps) with X11 output of VLC. And you cannot set it on QT. If you would set anyway, it would be so low on performance.
    I finally figured it out, I am being busy with something impossible for 2 months :D
    Thanks everyone on this forum, anyway!
  3. waltervl
    I am sorry to hear this. As this is a QT question I did not answer because I have no experience in this. The video part though I could have warned you for that. But there are numerous topics on this forum warning people to not use the Udoo for video output as it has a weak GPU. As an IoT device it was also not designed to do so.
    But a feel with you. I also have struggled with some applications that after all were not possible at all.
    evaloverde likes this.
