Hi All. I received my Bolt last night. I have been watching the temps, because of some of the problems I've seen in the forums. My temperatures, have been great, but I realized that lm_sensors doesn't say CPU temp. I was assuming the K10temp was CPU, and it does go up if I run stress cpu hog threads. Here is a screenshot of my sensors - which one is CPU? Thanks.
interested in the same, it seems the k10 (cpu?) and amdgpu-pci :: temp1 (gpu?) run about the same temp when i was doing a 4 thread stress test. it makes sense as they are a single package i suppose. is there value in monitoring separately? or will they always be roughly the same
I believe the first sensor is in the Intel WiFi card (it seems to run hotter than the non-stressed CPU), the second is the power adapter, the third is the GPU and last is the CPU. But to be honest I am not 100% sure.
Hello @Andy Carlson , would you please tell us which software you are using to check the cpu temperatures? I am using and have to use Ubuntu 18.04 ... I tried lm-sensors, but it didn't find any sensors. Cheers, DJVT
@DJVT Just use more recent kernel and you will be able to access ivi sensors; Code: root@bolt:~# lsb_release -i -r Distributor ID: Ubuntu Release: 19.10 root@bolt:~# uname -a Linux bolt 5.3.0-24-generic #26-Ubuntu SMP Thu Nov 14 01:33:18 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux root@bolt:~# sensors amdgpu-pci-0500 Adapter: PCI adapter vddgfx: N/A vddnb: N/A edge: +42.0°C (crit = +80.0°C, hyst = +0.0°C) acpitz-acpi-0 Adapter: ACPI interface temp1: +42.5°C (crit = +99.0°C) temp2: +10.0°C (crit = +125.0°C) k10temp-pci-00c3 Adapter: PCI adapter Tdie: +42.5°C (high = +70.0°C) Tctl: +42.5°C
Thank you @Zgembo, unfortunately I am tied to Ubuntu 18.04 LTS and Kernel 5.0 because of some software and hardware I am using. Update, acpi works on 18.04 with 5.0 Kernel: $ sudo apt install acpi $ acpi -t Thermal 0: ok, 10.0 degrees C Thermal 1: ok, 46.5 degrees C idk what Thermal 0 is though. It is 10°C constantly, so probably misinterpreted data...
