Problems with native libraries on UDOO
Discussion in 'Troubleshooting' started by JDorval, Jan 23, 2014.
  1. JDorval
    JDorval New Member
    Jan 23, 2014
    Hello, i've tried multiple projects with external Jars and natives.
    Everytime i try to launch, I get unsatisfiedlink errors,
    I try to use the -Djava.library.path option and it is not working... i also tried to create runnable jars, fat jar but i'm always getting this error.
    I've also tried to do:
    static{
    		try
    			System.load("test_lib/librxtxSerial.so");
    		}catch(UnsatisfiedLinkError e)
    			e.printStackTrace();
    			System.exit(1);
    Directly in the main class, but no success... Anyone have a solution or any hint ? Thanks :)
    It's working perfectly fine on a ubuntu PC..
  2. swoofer
    swoofer New Member
    Dec 26, 2013
    i have same problem HELP ME!!!
  3. venkatbo
    venkatbo Member
    45
    What is the stack trace - an FNF kind of msg maybe ?
    /v
  4. swoofer
    swoofer New Member
    Dec 26, 2013
    ubuntu@udoo:~/Desktop/test/libs$ ls
    RXTXcomm.jar librxtxSerial.so
    ubuntu@udoo:~/Desktop/test/libs$ cd ..
    ubuntu@udoo:~/Desktop/test$ ls
    Wodka_fat.jar libs
    ubuntu@udoo:~/Desktop/test$ java -jar Wodka_fat.jar
    java.lang.UnsatisfiedLinkError: no rxtxSerial in java.library.path thrown while loading gnu.io.RXTXCommDriver
    Exception in thread "main" java.lang.UnsatisfiedLinkError: no rxtxSerial in java.library.path
    at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1681)
    at java.lang.Runtime.loadLibrary0(Runtime.java:840)
    at java.lang.System.loadLibrary(System.java:1047)
    at gnu.io.CommPortIdentifier.<clinit>(CommPortIdentifier.java:123)
    at controller.utilities.SerialCommunicator.<init>(SerialCommunicator.java:28)
    at controller.WodkaController.<init>(WodkaController.java:27)
    at controller.WodkaController.main(WodkaController.java:50)
  5. venkatbo
    venkatbo Member
    45
  6. swoofer
    swoofer New Member
    Dec 26, 2013
    installing lib with terminal
    sudo apt-get install librxtx-java
    After doing this, the libs should be in /usr/lib/jni
    Now just run the jar and tell the JVM to look in this folder for the library
    java -Djava.library.path=/usr/lib/jni -jar FileName.jar
    Sucess!
    thx for help
