Why do you want to overclock it? The 3.6GHz are the turbo boost... cpu will "overclock" by itsself when the power is needed.
I want to overclock the CPU to played 51 Leagues in Football Manager as so far, it can run 25 leagues at faster speed at the moment.
I have three main suggestions to improve the situation. Update the drivers. This will improve overall performance and stability. Increase the airflow of the system since the higher clocks mean higher temperatures, and this can hurt the chip if exposed to too high of temperatures for too long. Change the power settings - For Windows - Enable Game Mode. For Windows ( alternate) - Change the windows Power Plan setting to "High Performance". The default Power Plan is "Balanced". For Linux - Change the cpu governer settings.
