Gear - Will not boot to NVMe
Discussion in 'UDOO BOLT' started by moxy, Aug 20, 2020.
  1. moxy
    moxy UDOOer
    Aug 20, 2019
    I have my bios boot sequence set to boot to the NVMe Windows boot loader as the first option but it just ends up hanging.
    When I go down to override boot sequence, and select Windows boot loader, it starts up perfectly fine.
    This is a bit of problem because I want to run the Gear headless but if it can't reboot, this is useless. Anyone else having this issue?
  2. rdslw
    rdslw UDOOer
    Apr 5, 2014
    38
    17
  3. waltervl
    Do you have other OS's like Linux installed or just only Windows?
    Did you change other related Bios options?
    Did you try to reset Bios to factory settings?
  4. moxy
    moxy UDOOer
    Aug 20, 2019
    Yes, I did all that.
    I gave up with it and swapped it out with a non NVME drive and it works fine. So there is something borked with the BIOS for NVME Windows boot drives.
